Curves for 6G6G tube
2/15/2002 9:57:48 AMRob Mercure
Folks,
Have a few WWII surplus 6G6Gs and wondered if anyone had design curves for this low wattage audio pentode?
Rob
2/15/2002 1:41:56 PMNorm Leal
Hi Rob
Use curves of the more modern 6AK6 for 6G6G.
12K5 was operated with grid #1 tied to 12 volts and grid #2 input. Don Black and I recently discussed this tube. Don may reply to you 12K5 posing.
: Folks,
: Have a few WWII surplus 6G6Gs and wondered if anyone had design curves for this low wattage audio pentode?
: Thanks
: Rob
2/15/2002 2:46:26 PMRob Mercure
Hey Norm,
Thanks for the reply. Luckily I've got one of the few RCA Tube Manuals that include the 12K5 so I've got some operation specs. What I don't understand is how it works. Is g1 wound really "open" so it will capture few electrons - sort of an "accelerator" grid before the control grid?
If you communicate with Don please get him to relay any info - I'm considering crafting a "portable" micro-power amp using this bottle and other 12V Ep tubes - might power it with camcorder gel cells.
Rob
: Hi Rob
: Use curves of the more modern 6AK6 for 6G6G.
: 12K5 was operated with grid #1 tied to 12 volts and grid #2 input. Don Black and I recently discussed this tube. Don may reply to you 12K5 posing.
: Norm
: : Folks,
: : Have a few WWII surplus 6G6Gs and wondered if anyone had design curves for this low wattage audio pentode?
: : Thanks
: : Rob
2/16/2002 7:45:08 AMDon Black
Hi Rob, You might condider using the 12AL8, that has the same output tube as the 12K5 but also includes a matching triode AF tube to drive it. The 12U7 may also be useful, it's a twin triode for 12 volt operation. If you want to be really inovative, how about push pull with a pair of these tubes, should get 100 mw or so. Interesting exercise. I'll scan the circuit for the 12AL8 from a data book and send you, shows typical operation.
Don Black.
: Hey Norm,
: Thanks for the reply. Luckily I've got one of the few RCA Tube Manuals that include the 12K5 so I've got some operation specs. What I don't understand is how it works. Is g1 wound really "open" so it will capture few electrons - sort of an "accelerator" grid before the control grid?
: If you communicate with Don please get him to relay any info - I'm considering crafting a "portable" micro-power amp using this bottle and other 12V Ep tubes - might power it with camcorder gel cells.
: Rob
: : Hi Rob
: : Use curves of the more modern 6AK6 for 6G6G.
: : 12K5 was operated with grid #1 tied to 12 volts and grid #2 input. Don Black and I recently discussed this tube. Don may reply to you 12K5 posing.
: : Norm
: : : Folks,
: : : Have a few WWII surplus 6G6Gs and wondered if anyone had design curves for this low wattage audio pentode?
: : : Thanks
: : : Rob
