pins on 33 tube
12/1/2013 8:26:42 PMJack
Which pin would be the #1 pin on a 33. Know that some tubes have larger pins.It's very common for there to be a gap. But, the 33 has 2 gaps that are the same distance between the two pins. making a 1 tube project and I don't want to wire it wrong.
12/1/2013 10:10:13 PMWarren
Looking at the bottom of the tube, it's pin 1 the fat pin on the left. Count clockwise to pin number 5, that's the other fat pin for the filament.
12/1/2013 10:53:24 PMjack
:Looking at the bottom of the tube, it's pin 1 the fat pin on the left. Count clockwise to pin number 5, that's the other fat pin for the filament.
thanks
12/2/2013 12:23:14 AMjack
My schematic has pins 3 and 4 for the filament . while the one that is separated from the other 4 is pin 1 and it is for the plate.
12/2/2013 8:43:19 AMCarl T
::Looking at the bottom of the tube, it's pin 1 the fat pin on the left. Count clockwise to pin number 5, that's the other fat pin for the filament.
:My schematic has pins 3 and 4 for the filament . while the one that is separated from the other 4 is pin 1 and it is for the plate.
Jack,
Here's a base diagram:
http://www.nj7p.org/Common/Tube/SQL/Tube_query.php?Type=33
Carl T
12/2/2013 10:26:16 AMJack
:::Looking at the bottom of the tube, it's pin 1 the fat pin on the left. Count clockwise to pin number 5, that's the other fat pin for the filament.
::My schematic has pins 3 and 4 for the filament . while the one that is separated from the other 4 is pin 1 and it is for the plate.
:Jack,
:Here's a base diagram:
:http://www.nj7p.org/Common/Tube/SQL/Tube_query.php?Type=33
:Carl T
Thanks! For those who want to look at the book I am using. It's the No.2 book of those little yellow "Gernsback's Educational Library. How to Make The Most Popular All wave 1 and 2 Tube receivers. The radio is on the last page. Could the book be wrong, or did they number the pins differently then?
12/3/2013 4:11:27 PMThomas
