11/18/2013 5:43:30 PMharold(109388:0)
I could use a simplified schematic of the pushbutton switch wiring for B/Cast, SW, FM and pre set push buttons. The diagram switch wiring modes is a "jungle".
All I want is the Broadcast, manual tuning to function; maybe re-wiring a bit to bypass some switches. Any help greatly appreciated.
Harold
11/18/2013 7:38:34 PMGeorge T(109392:109388)
:I could use a simplified schematic of the pushbutton switch wiring for B/Cast, SW, FM and pre set push buttons. The diagram switch wiring modes is a "jungle".
:All I want is the Broadcast, manual tuning to function; maybe re-wiring a bit to bypass some switches. Any help greatly appreciated.
:Harold
Hi Harold, it will probably be next to impossible to find a simplified schematic for that model. But more than likely the push buttons and switch work and just need cleaned up a bit and boken and bare wires need replaced or repaired. You could probably get a schematic for that model from "Just Radios" but you won't know until you get it if it is easier to read. I'm not sure about that model but on several of the other models with the push buttons from that time period the first push button is the on/off switch to power up the radio. Good Luck, George T
