Much obliged,
Paul
Much obliged for the quick reply. Is there an advantage to the loop antennas mounted on the backs of some models? Would a period correct Philco loop antenna from another model do a better or worse job?
presence. . . . . and not a high or open situation.
Sir Paul . . . . . . .
You really need to ohm out the antenna coils primary and secondary windings for their properly having a quite low resistance
Also, another very simple technical evaluation can be made on the Broadcast band , prior to any of that test equipment usage, by merely moving that temporary 10-20 foot of wire to be used as an aerial, over to the grid cap on the very top of the 6A8 toobie.
If its bringing in stations now . . . . albeit with some possible "donald duck"/ or / talking underwater burbling sounds on stronger stations .
If this last testing situation is working better than thru the sets antenna terminals input, then you REALLY need to suspect the antenna coil OR, its having a a connectivity problem getting RF signal to it.
A burrito is a sleeping bag for ground beef. .
:Your radio uses a long wire antenna. There is an antenna coil in your radio. This antenna coil is what connects to the long wire. The coil could have an open winding. That's why such poor reception.
: : : : : ![]() : : : : : :Sir Paul . . . . . . . : : :You really need to ohm out the antenna coils primary and secondary windings for their properly having a quite low resistance : : presence. . . . . and not a high or open situation. : : :Also, another very simple technical evaluation can be made on the Broadcast band , prior to any of that test equipment usage, by merely moving that temporary 10-20 foot of wire to be used as an aerial, over to the grid cap on the very top of the 6A8 toobie. : : :If its bringing in stations now . . . . albeit with some possible "donald duck"/ or / talking underwater burbling sounds on stronger stations . : : :If this last testing situation is working better than thru the sets antenna terminals input, then you REALLY need to suspect the antenna coil OR, its having a a connectivity problem getting RF signal to it. : : : : : : : : : : :73's de Edd : : : : : : : : : : :A burrito is a sleeping bag for ground beef. . : : : : : : : ![]() |
What you DID find by that far out in left field approach, of the looped out wire coat hanger onto the END of that 16 feets of "war", IS telling us, is that you established for yourself, what we in the antenna trade . . . . are referring to as a "capacitive top hat. " (If in the house proper . . . .you can also get the same effect by connecting onto a set of METAL wire bed "sprangs" ) Technically, what this produced effect of the extra added on capacitance of the " top hat" is telling us . . . . . is that your external aerial wire needs to be loooooooooooooonger. ::Thanks everyone for all the great feedback. Making some progress. I happened to have a Magnavox loop antenna and when I connect it, bingo, got radio reception. But since all are saying this had a long wire I'm trying to make that work. Connected 16 feet of wire and the reception was poor. Just for laughs, I took a wire hanger, make a loop out of it and connected that to the end of the 16 ft section. Got great reception. What am I doing wrong here?
I would shore nuff need more exacting info on that loose term of a "Magnavox loop", in order to make an intelligent and more precise evaluation of the situation.
Like, if it is a loop with an external antenna input connection AND another multi turn winding for connection to the RF section of the tuning condenser.
AND . . .did you completely pull the Philco antenna coil and put the Maggotbox in its place ?
OR did you just try connecting the Mag loops winding(s) into the existing Philco antenna coil input ?
Uhhhhhhh Ohhhhhhh . . . . . . now I am hearing . . . . .ME TOO ! ME TOO ! . . . . .coming from that metal meshed window screen , just above . . . .on my window . . . as being an ALSO like alternative.
Hint :
A temporary wire length evaluation can be made by tying into the prongs of a 50-100- ? long orange/or/red/or/yaller) electrical extension cord.
Then you can adjust it into any intermediate length or form the wire into a coil at its part closest to the radio to make a "loading coil" to make the wire perform ELECTRICALLY like its actually even looooooooooooooonger than it PHYSICALLY is.
This is a universally common practice on . . . .AM auto-mo-bubble antennas, with their inherently SHORT whips.
Thasssssittttt . . . . .
When someone hands you a flyer, it’s like they’re saying “Here, YOU throw this away.” . .
::Sir Paul . . . . . . .
::You really need to ohm out the antenna coils primary and secondary windings for their properly having a quite low resistance
:: presence. . . . . and not a high or open situation.
::Also, another very simple technical evaluation can be made on the Broadcast band , prior to any of that test equipment usage, by merely moving that temporary 10-20 foot of wire to be used as an aerial, over to the grid cap on the very top of the 6A8 toobie.
::If its bringing in stations now . . . . albeit with some possible "donald duck"/ or / talking underwater burbling sounds on stronger stations .
::If this last testing situation is working better than thru the sets antenna terminals input, then you REALLY need to suspect the antenna coil OR, its having a a connectivity problem getting RF signal to it.
::73's de Edd
::A burrito is a sleeping bag for ground beef. .
:::Your radio uses a long wire antenna. There is an antenna coil in your radio. This antenna coil is what connects to the long wire. The coil could have an open winding. That's why such poor reception.
