Clifton
::Not well. If it has two 45s it has a push-pull output; running with just one tube will result in distorted sound. Try it and see; it won't hurt anything.
:Thanks CV, playing a little tells me rest of tubes/radio ok
Clifton
::Does the other 45 tube have an open filament? Or just doesn't light in it's socket. Tried measuring between the filament pins of the tube. If no continuity might try resoldering the filament pins with a bit of fresh solder.
::Clifton
::Hello Clifton, other 45 tube does show continuity between 2 larger pins, but surprising does not light up, had to melt a lot of solder dowm larger pins. will get back on it tonight [fri]
::::Not well. If it has two 45s it has a push-pull output; running with just one tube will result in distorted sound. Try it and see; it won't hurt anything.
:::Thanks CV, playing a little tells me rest of tubes/radio ok
I believe he mentioned that one of the 45s did not light up.
Clifton
:The radio should play with one 45 tube in ether socket. If not you may have a fault with the taped audio output transformer.
Swapping the two tubes as suggested is probably the fastest way to differentiate betwen tube problems and socket/wiring problems. The only thing that I would add is that sometimes these ancient tubes (and sockets!) acquire an oxidation on the pins which is nonconductive. Brightening up the pins of the "dead" tube with 600 grit sandpaper and scraping the socket contacts with an X-Acto knife might be helpful.
