Thordarson numbers appear to be 2 numbers, then a letter. I can't find anything beginning with "27"
Could be a special for an OEM.
Rich
http://www.junkbox.com/electronics/Thordarson%20Transformer%20Catalog%201942.pdf
Sir Mike . . . . . . . . . Here are some more research sites to throw at you : http://www.junkbox.com/electronics/Thordarson%20Transformer%20Catalog%201942.pdf http://www.junkbox.com/electronics/Stancor61-62Catalog.pdf http://www.alliedcatalogs.com/catalogs_main 73's de Edd
::I picked up junk pile of radio parts at auction and a Thordarson type 2724A transformer. The transformer plugs into a wall outlet and has a 3v tap and a receptical that gets line voltalge at 116V... Not sure what exactly this transformer is or would be used for..? I would say it is late 1930s vintage..sealed in tar w/ wblack wrinkle paint finish..quite large... Isolation transforme???(not sure what that is either) maybe someone can explain...
::Thanks
:Thordarson numbers appear to be 2 numbers, then a letter. I can't find anything beginning with "27"
:Could be a special for an OEM.
:Rich
:http://www.junkbox.com/electronics/Thordarson%20Transformer%20Catalog%201942.pdf
