old radio shows on the air
10/14/2013 10:13:29 PMJack
Know this is a little off topic from repairing old tube radios. But, thought those who love such radios might know. Are there any stations that broadcast old radio shows. Either on AM or shortwave?
listening by computer is a drag.
10/14/2013 10:30:39 PMGeorge T
:Know this is a little off topic from repairing old tube radios. But, thought those who love such radios might know. Are there any stations that broadcast old radio shows. Either on AM or shortwave?
:listening by computer is a drag.
Hi Jack, if you like the songs of the 1920's thru the 40's check out "Radio Dismuke" as for listening thru your computer make yourself an AM transmitter then you can listen thru your old radios and transmit from your computer. "SStrans" provides a DIY kit that I use and it works great. Been using my SStrans every night for over 3 years now. Best 2 U, George T
10/14/2013 10:32:49 PMGeorge T
::Know this is a little off topic from repairing old tube radios. But, thought those who love such radios might know. Are there any stations that broadcast old radio shows. Either on AM or shortwave?
::listening by computer is a drag.
:Hi Jack, if you like the songs of the 1920's thru the 40's check out "Radio Dismuke" as for listening thru your computer make yourself an AM transmitter then you can listen thru your old radios and transmit from your computer. "SStrans" provides a DIY kit that I use and it works great. Been using my SStrans every night for over 3 years now. Best 2 U, George T
PS you can find old radio show on You Tube.
10/14/2013 10:34:23 PMJack
Thanks!
Downloaded several dozen radio programs such as the War of the Worlds, calling all cars, Boston Blackie,etc. Computers just isn't the same.
10/16/2013 1:14:40 PMAUSTIN
:::Know this is a little off topic from repairing old tube radios. But, thought those who love such radios might know. Are there any stations that broadcast old radio shows. Either on AM or shortwave?
:::listening by computer is a drag.
::Hi Jack, if you like the songs of the 1920's thru the 40's check out "Radio Dismuke" as for listening thru your computer make yourself an AM transmitter then you can listen thru your old radios and transmit from your computer. "SStrans" provides a DIY kit that I use and it works great. Been using my SStrans every night for over 3 years now. Best 2 U, George T
::check out "WHEN RADIO WAS"(AM)in different areas
:Thanks!
:Downloaded several dozen radio programs such as the War of the Worlds, calling all cars, Boston Blackie,etc. Computers just isn't the same.
10/18/2013 12:30:06 PMAUSTIN
::::Know this is a little off topic from repairing old tube radios. But, thought those who love such radios might know. Are there any stations that broadcast old radio shows. Either on AM or shortwave?
::::listening by computer is a drag.
:::Hi Jack, if you like the songs of the 1920's thru the 40's check out "Radio Dismuke" as for listening thru your computer make yourself an AM transmitter then you can listen thru your old radios and transmit from your computer. "SStrans" provides a DIY kit that I use and it works great. Been using my SStrans every night for over 3 years now. Best 2 U, George T
:::check out "WHEN RADIO WAS"(AM)also FM in different areas
::Thanks!
::Downloaded several dozen radio programs such as the War of the Worlds, calling all cars, Boston Blackie,etc. Computers just isn't the same.
10/18/2013 12:30:07 PMAUSTIN
::Thanks!
10/16/2013 4:57:27 PMMm
10/16/2013 4:58:31 PMMmakazoo
Jack: How close are you to Toronto? Here in Michigan I can get AM 740 at night and they play old programs at 10pm eastern time. Mark from Kalamazoo
10/18/2013 11:44:33 AMJerry
:Jack: How close are you to Toronto? Here in Michigan I can get AM 740 at night and they play old programs at 10pm eastern time. Mark from Kalamazoo
I live near Albany, NY and I listen to 2 stations over the air:
http://www.900chml.com/old-radio-shows/
and
WABY - Albany 1160AM Saturdays 10:00 till 3:00, music and radio shows
10/19/2013 1:00:07 AMJack
::Jack: How close are you to Toronto? Here in Michigan I can get AM 740 at night and they play old programs at 10pm eastern time. Mark from Kalamazoo
:I live near Albany, NY and I listen to 2 stations over the air:
:http://www.900chml.com/old-radio-shows/
:and
:WABY - Albany 1160AM Saturdays 10:00 till 3:00, music and radio shows
Live way south. Around Texas.
10/19/2013 5:11:50 PMRick
What is it about 740? I am really blessed living in Boston: 740 WJIB plays 40's - 70's music 24/7. Best of all: no commercials - it's totally listener supported.
But it's a really low power station under old rules - it has to switch to only 5 watts at sunset to make way for 740 from Toronto. I've got real creative with loop antennas to pick it up at night.
10/19/2013 6:13:01 PMTerry F
Not radio stations, but a little bit of the past.
http://www.otr.net/?p=abco
Terry F
10/21/2013 8:32:57 PMChuck Harris
:Not radio stations, but a little bit of the past.
:http://www.otr.net/?p=abco
:Terry F
Try these :
www.dumb.com/oldtimeradio
www.RadioLovers.com
www.archive.org/details/radioprograms
Chuck
10/29/2013 8:49:59 AMBill G.
You may want to check out a Christian radio station.
They produce new run radio dramas in the tradition of the radio drama art form. Often they are quite good.
"Adventures in Odyssey" and "Paws and Tales" are two that come to mind.
Best regards,
Bill Grimm
