I used this schematic to make my audio amplifier, works great. I would like to add some base to the sound.
Can anyone suggest a mod to the circuit to give the output some base?
Thank you,
Mitch
Might take a look at an LM386 amp with tone circuit here:
http://www.qrp.pops.net/misc_2005.asp
Clifton
:Hello everyone,
:I used this schematic to make my audio amplifier, works great. I would like to add some base to the sound.
:Can anyone suggest a mod to the circuit to give the output some base?
:Thank you,
:Mitch
I took the lazy man's way out. I finally settled on a .047uF capacitor and a 10K resistor in series installed between pin 1 and pin 5 of the LM386 amp. This is producing the sound I am satisfied with.
Mitch
I took my own advice and built a two channel audio amplifier, works great with my turntable.
Listening to a 1955 Platters 16 Greatest Hits album ("Smoke Gets In Your Eyes") with my home brew amplifier.
Works with a 9 volt battery, on high volume it will blow you out of the room, any ideas on the wattage from this audio amp?
Mitch
Thank you,
Mitch
It's probably in the low hundreds of milliwatt range per channel. A higher audio output level would make the amp eat 9V batteries like popcorn.
You could figure it out by measuring the current out of the battery when playing a record at high (undistorted) volume, dividing by 2, and applying the P=IV relationship. This is an "outside" approximation since the amp isn't 100% efficient and the record you choose (probably) has variable sound levels; but it will get you in the ballpark- or at least the parking lot.
The turntable does not have a built in RIAA circuit. I can make one for the two channels.
What do you think of this design?
http://www.reprise.com/host/circuits/riaa_preamp.asp
Responses welcome,
Mitch
