http://www.nostalgiaair.org/Resources/421/M0043421.htm
both transformers have the same part number.
:Hello All,
: I started working on this radio in 2007 and then it got put into storage. I had removed one of the RF transformers because it was open. I need to know what transformer will work as a replacement. The one that's missing is identical to the one that's still there. Maybe someone has a little more service data for the Model 27, as well. In the schematic:
:http://www.nostalgiaair.org/Resources/421/M0043421.htm
:both transformers have the same part number.
:Thanks,
:Dave
The 3 RF coils should match for proper tracking.
PTOP has coils.
http://www.oldradioparts.com/pg2a6.htm
:Hello Again,
: There is a part number on the schematic for this coil:
:71W 22678. Maybe that will help find one.
:Thanks,
:Dave
::Hello All,
:: I started working on this radio in 2007 and then it got put into storage. I had removed one of the RF transformers because it was open. I need to know what transformer will work as a replacement. The one that's missing is identical to the one that's still there. Maybe someone has a little more service data for the Model 27, as well. In the schematic:
::http://www.nostalgiaair.org/Resources/421/M0043421.htm
::both transformers have the same part number.
::Thanks,
::Dave
:Dave
: The 3 RF coils should match for proper tracking.
: PTOP has coils.
:http://www.oldradioparts.com/pg2a6.htm
::Hello Again,
:: There is a part number on the schematic for this coil:
::71W 22678. Maybe that will help find one.
::Thanks,
::Dave
:::Hello All,
::: I started working on this radio in 2007 and then it got put into storage. I had removed one of the RF transformers because it was open. I need to know what transformer will work as a replacement. The one that's missing is identical to the one that's still there. Maybe someone has a little more service data for the Model 27, as well. In the schematic:
:::http://www.nostalgiaair.org/Resources/421/M0043421.htm
:::both transformers have the same part number.
:::Thanks,
:::Dave
:Dave
: PTOP has coils.
::Hello Again,
::Thanks,
::Dave
:::Hello All,
:::Thanks,
:::Dave
Since this is a one dial radio with three tuned circuits they should all track together. Your antenna coil and two RF coils should have the same tuned sections.
You could try a coil designed for broadcast band. Could also change all three as a matched set. Think I would try a couple coils designed for broadcast first. Should be something close.
Might call Gary at PTOP. He has a good idea what he has in stock.
:Norm,
: This radio has an antenna coil and two RF coils. I don't see a third one. It's not on the schematic. Another similar model (that there's a diagram of in Riders on a page near the 28 (aka. 27)) has 3 but this one has the two 71W 22678 RF transformers.
: I just checked the input and output transformers on the amplifier and they're both open. There is no connection from B+ to any connection on the input transformer (T7 71W-22933 on the schematic). The output transformer is a part of that old style speaker. I plan on using a more modern speaker, so I'm going to need to find the right one at PTOP too. But which one, I have no idea. But I can figure out out put transformers easier than I input transformers or RF transformers.
:Thanks,
:Dave
::Dave
:: The 3 RF coils should match for proper tracking.
:: PTOP has coils.
::http://www.oldradioparts.com/pg2a6.htm
:::Hello Again,
::: There is a part number on the schematic for this coil:
:::71W 22678. Maybe that will help find one.
:::Thanks,
:::Dave
::::Hello All,
:::: I started working on this radio in 2007 and then it got put into storage. I had removed one of the RF transformers because it was open. I need to know what transformer will work as a replacement. The one that's missing is identical to the one that's still there. Maybe someone has a little more service data for the Model 27, as well. In the schematic:
::::http://www.nostalgiaair.org/Resources/421/M0043421.htm
::::both transformers have the same part number.
::::Thanks,
::::Dave
Thanks very much,
:Dave
: Since this is a one dial radio with three tuned circuits they should all track together. Your antenna coil and two RF coils should have the same tuned sections.
: You could try a coil designed for broadcast band. Could also change all three as a matched set. Think I would try a couple coils designed for broadcast first. Should be something close.
: Might call Gary at PTOP. He has a good idea what he has in stock.
::Norm,
:: This radio has an antenna coil and two RF coils. I don't see a third one. It's not on the schematic. Another similar model (that there's a diagram of in Riders on a page near the 28 (aka. 27)) has 3 but this one has the two 71W 22678 RF transformers.
:: I just checked the input and output transformers on the amplifier and they're both open. There is no connection from B+ to any connection on the input transformer (T7 71W-22933 on the schematic). The output transformer is a part of that old style speaker. I plan on using a more modern speaker, so I'm going to need to find the right one at PTOP too. But which one, I have no idea. But I can figure out out put transformers easier than I input transformers or RF transformers.
::Thanks,
::Dave
:::Dave
::: The 3 RF coils should match for proper tracking.
::: PTOP has coils.
:::http://www.oldradioparts.com/pg2a6.htm
::::Hello Again,
:::: There is a part number on the schematic for this coil:
::::71W 22678. Maybe that will help find one.
::::Thanks,
::::Dave
:::::Hello All,
::::: I started working on this radio in 2007 and then it got put into storage. I had removed one of the RF transformers because it was open. I need to know what transformer will work as a replacement. The one that's missing is identical to the one that's still there. Maybe someone has a little more service data for the Model 27, as well. In the schematic:
:::::http://www.nostalgiaair.org/Resources/421/M0043421.htm
:::::both transformers have the same part number.
:::::Thanks,
:::::Dave
Dave,
I always have taken that to mean don't ask me to go out looking for parts for you that I don't have. Rather than don't ask me if I have something.
Richard
:: Gary has something on his website like "don't ask me to help you find a part". So I'm not sure he will help. So please help if you can.
:Dave,
:I always have taken that to mean don't ask me to go out looking for parts for you that I don't have. Rather than don't ask me if I have something.
:Richard
Use a transformer similar to Stancor A53C. Both AES and Radio Daze has these. PTOP should also. Look for an audio interstage transformer with ratio 1:3 or around that.
:Richard,
: Yes, I do ask if something listed is in stock. But he does't help pick out something, or answer a design or technical question, like we discuss in this forum. Anyway, I like PTOP. The next thing I need to know is which input transformer will replace the one in the Crosley 27. The output transformer needs to match the 10K ohms to 4 or 8 ohms. It should also be designed to work with the .8 watt output. Once the amplifier is working, I will be able to hear the tuner.
:Thanks,
:Dave
::: Gary has something on his website like "don't ask me to help you find a part". So I'm not sure he will help. So please help if you can.
::Dave,
::I always have taken that to mean don't ask me to go out looking for parts for you that I don't have. Rather than don't ask me if I have something.
::Richard
Thanks very much,
:Dave
: Use a transformer similar to Stancor A53C. Both AES and Radio Daze has these. PTOP should also. Look for an audio interstage transformer with ratio 1:3 or around that.
::Richard,
:: Yes, I do ask if something listed is in stock. But he does't help pick out something, or answer a design or technical question, like we discuss in this forum. Anyway, I like PTOP. The next thing I need to know is which input transformer will replace the one in the Crosley 27. The output transformer needs to match the 10K ohms to 4 or 8 ohms. It should also be designed to work with the .8 watt output. Once the amplifier is working, I will be able to hear the tuner.
::Thanks,
::Dave
:::: Gary has something on his website like "don't ask me to help you find a part". So I'm not sure he will help. So please help if you can.
:::Dave,
:::I always have taken that to mean don't ask me to go out looking for parts for you that I don't have. Rather than don't ask me if I have something.
:::Richard
Clifton
:Norm,
: OK, I found all the transformers except the output transformer. I have searched and searched but there doesn't seem to be low power, even a universal model that has the 10K ohms and Push Pull to voice coil for battery tube sets. The lowest power I can find is in a Stancor catalog.
: I found an unknown on the PTOP website but that's for a single plate 3V4. Is there one I missed? I believe it's an 8 inch 1 watt speaker. I need to replace that too. Maybe PTOP has a speaker with the transformer on it that will work.
:Thanks very much,
:Dave
::Dave
:: Use a transformer similar to Stancor A53C. Both AES and Radio Daze has these. PTOP should also. Look for an audio interstage transformer with ratio 1:3 or around that.
:::Richard,
::: Yes, I do ask if something listed is in stock. But he does't help pick out something, or answer a design or technical question, like we discuss in this forum. Anyway, I like PTOP. The next thing I need to know is which input transformer will replace the one in the Crosley 27. The output transformer needs to match the 10K ohms to 4 or 8 ohms. It should also be designed to work with the .8 watt output. Once the amplifier is working, I will be able to hear the tuner.
:::Thanks,
:::Dave
::::: Gary has something on his website like "don't ask me to help you find a part". So I'm not sure he will help. So please help if you can.
::::Dave,
::::I always have taken that to mean don't ask me to go out looking for parts for you that I don't have. Rather than don't ask me if I have something.
::::Richard
:Is space to put the transformer the problem?
:Clifton
::Norm,
:: OK, I found all the transformers except the output transformer. I have searched and searched but there doesn't seem to be low power, even a universal model that has the 10K ohms and Push Pull to voice coil for battery tube sets. The lowest power I can find is in a Stancor catalog.
:: I found an unknown on the PTOP website but that's for a single plate 3V4. Is there one I missed? I believe it's an 8 inch 1 watt speaker. I need to replace that too. Maybe PTOP has a speaker with the transformer on it that will work.
::Thanks very much,
::Dave
:::Dave
::: Use a transformer similar to Stancor A53C. Both AES and Radio Daze has these. PTOP should also. Look for an audio interstage transformer with ratio 1:3 or around that.
::::Richard,
:::: Yes, I do ask if something listed is in stock. But he does't help pick out something, or answer a design or technical question, like we discuss in this forum. Anyway, I like PTOP. The next thing I need to know is which input transformer will replace the one in the Crosley 27. The output transformer needs to match the 10K ohms to 4 or 8 ohms. It should also be designed to work with the .8 watt output. Once the amplifier is working, I will be able to hear the tuner.
::::Thanks,
::::Dave
:::::: Gary has something on his website like "don't ask me to help you find a part". So I'm not sure he will help. So please help if you can.
:::::Dave,
:::::I always have taken that to mean don't ask me to go out looking for parts for you that I don't have. Rather than don't ask me if I have something.
:::::Richard
Clifton
:Clifton,
: There's plenty of space.
:Dave
::Is space to put the transformer the problem?
::Clifton
:::Norm,
::: OK, I found all the transformers except the output transformer. I have searched and searched but there doesn't seem to be low power, even a universal model that has the 10K ohms and Push Pull to voice coil for battery tube sets. The lowest power I can find is in a Stancor catalog.
::: I found an unknown on the PTOP website but that's for a single plate 3V4. Is there one I missed? I believe it's an 8 inch 1 watt speaker. I need to replace that too. Maybe PTOP has a speaker with the transformer on it that will work.
:::Thanks very much,
:::Dave
::::Dave
:::: Use a transformer similar to Stancor A53C. Both AES and Radio Daze has these. PTOP should also. Look for an audio interstage transformer with ratio 1:3 or around that.
::::Norm
:::::Richard,
::::: Yes, I do ask if something listed is in stock. But he does't help pick out something, or answer a design or technical question, like we discuss in this forum. Anyway, I like PTOP. The next thing I need to know is which input transformer will replace the one in the Crosley 27. The output transformer needs to match the 10K ohms to 4 or 8 ohms. It should also be designed to work with the .8 watt output. Once the amplifier is working, I will be able to hear the tuner.
:::::Thanks,
:::::Dave
::::::: Gary has something on his website like "don't ask me to help you find a part". So I'm not sure he will help. So please help if you can.
::::::Dave,
::::::I always have taken that to mean don't ask me to go out looking for parts for you that I don't have. Rather than don't ask me if I have something.
::::::Richard
