in the ~5-8V spectrum and fire up the set and take note of the voltage: . |
::You might examine both sections of the tuning capacitor very carefully as you rotate it fully meshed- do the plates touch at some point, due to a bent plate or nicked plate edge? If a short between stator and rotor is happening at some point on either section, it will kill reception. Because the plates engage more fully at low frequencies, a short like this is more likely to take out the lower tuning range.
:Hi CV, No such luck. I remove and chacked the tuning capacitor. There were no shorts. The plates are super straight.
:Sir Greg . . . .
:Vell its dun bin lookink dat der mentioned easy fix . . . vas not der solution. . . .
:Leaky C-5 or Gassy 35L6 . . . anyone ?
:Place a VTVM or a digital voltmeter on the 1st grid of the 12SA7, in DC mode for metering
:in the ~5-8V spectrum and fire up the set and take note of the voltage:
:1 . . . at the high end of the AM band
:2 . . . .at the low end of the AM band
:and most importantly, if it shifts or drops out somewhere between in the making of a full across band tuning sweep.
:I found there was only one way to look fashionably thin, just hang out with fat people.
:::You might examine both sections of the tuning capacitor very carefully as you rotate it fully meshed- do the plates touch at some point, due to a bent plate or nicked plate edge? If a short between stator and rotor is happening at some point on either section, it will kill reception. Because the plates engage more fully at low frequencies, a short like this is more likely to take out the lower tuning range.
::Hi CV, No such luck. I remove and chacked the tuning capacitor. There were no shorts. The plates are super straight.
