Is it OK to put some thin oil on the wafer's contacts of the rotary wafer-type switches ? Like sewing machine clear thin oil.
The Bands rotary switch doesn't switch easily in my set.
I cleaned up the wafers with contact cleaner, then relubricated the shaft and the 2 ball bearings, but that didn't help much.
Are you using a specific dielectric grease for all the metal contacts?
Generally the reason wafer switches are difficult to turn is not the wafer contacts but the position-detent mechanism. When the lube dries up on these they can become exceedingly difficult to turn. Since this part is non-electrical it's OK to lube it with petroleum-based oil or light grease.
Often I use Jig-A-Loo and I have good results
http://en.wikipedia.org/wiki/Jig-A-Loo
Jules
