no power on tubes
9/25/2013 7:54:41 AMRon
GE model 201 I replaced all caps except electrylitic 20 and 50 150 volt cap I plugged in dial light comes on but no power on tubes or no sound in speaker
9/25/2013 8:37:43 AMBrianC
If you had hum in the speaker before replacing the caps..go back over your work...if not...see if there's any B+ voltage on the 35Z5 rectifier pin 8 (if that's the tuber used in your set).
