silvertone 4569
9/20/2013 9:00:51 PMron
Hi I just recapped everything in unit I fired up I hear slight buzz and no green eye is it maybe a ground problem
9/20/2013 10:38:58 PMNorm Leal
Hi
The green eye requires pin #4 of a 6E5 or6U5 to have around 250 volts. Pin #5 should be near ground. Green in these tubes gets dim over time. If won't have an effect on reception.
Measure plate and screen voltages on tubes. These tube elements should be positive.
:Hi I just recapped everything in unit I fired up I hear slight buzz and no green eye is it maybe a ground problem
9/21/2013 1:46:37 PMMmakazoo
:Ron: How much experience do you have with radio repair? It sounds like you will need to take voltage measurements and see if you can localize the problem to a particular circuit and search for the problem. At least with a problem that is constant (not intermittent), you will know when you find the bad part (or parts). Do you have the schematic for your radio? Should have all the voltages, resistor values, etc.
Mark from Kalamazoo
9/21/2013 3:21:26 PMNorm Leal
Schematic can be found here:
http://www.nostalgiaair.org/Resources/116/M0017116.htm
::Ron: How much experience do you have with radio repair? It sounds like you will need to take voltage measurements and see if you can localize the problem to a particular circuit and search for the problem. At least with a problem that is constant (not intermittent), you will know when you find the bad part (or parts). Do you have the schematic for your radio? Should have all the voltages, resistor values, etc.
:Mark from Kalamazoo
