Oscilloscope, model 10-18
9/19/2013 9:45:52 PMDaniel M. Rine
Hello!
I have a Heathkit Model 10-18, and had to replace the fuse holder. The fuse and cap were missing. I have a 3amp-slow blow in the unit now.
My question is: will the 3amp fuse safe?
Thank you kindly!
Daniel
9/19/2013 11:17:18 PMCarl T
:Hello!
: I have a Heathkit Model 10-18, and had to replace the fuse holder. The fuse and cap were missing. I have a 3amp-slow blow in the unit now.
:My question is: will the 3amp fuse safe?
:Thank you kindly!
:Daniel
Daniel,
The schematic shows a 1-amp slow blow.
Carl T
9/19/2013 11:50:54 PMCV
3 amp SB is "safer" than a length of copper bus wire jammed in the holder, but not much. You can incur quite a bit of equipment damage before the fuse pops by using a fuse that is oversized for the application.
If the correct-size fuse blows frequently, it's a sign that there's a problem- such as deteriorated (leaky) power supply filter caps- in the equipment.
