keep my resistor cool
9/17/2013 5:08:10 PMBob
Rider 6 Emerson page 3 Model 19, out of dozens of speakers I have, only thing the fits is one with a PM. Speaker field is 3000 ohms what type of watts are we looking at? resistor line cord is 185 ohms @ 17 watts, would 7 watts work for speaker field??
9/17/2013 5:43:47 PMDoug Criner
Determine the B+ current, and figure wattage by I^R. Double the wattage rating for the resistor.
9/17/2013 5:44:57 PMDoug Criner
Correction:
Determine the B+ current, and figure wattage by I^2R. Double the wattage rating for the resistor.
9/17/2013 6:18:08 PMBob
Thanks, Not a math wizz, just a retired senior looking for a answer.
9/17/2013 6:34:13 PMWarren
The field coil is also the filter choke in the power supply. The full load of the radio is on this coil. Use a 10 watt resistor. That should keep it cool. You may need to up the MFD value of the filter capacitors to make up for the loss of the choke.
9/17/2013 7:13:03 PMCV
The speaker field is NOT the filter choke in this radio. This set has a separate 300 ohm choke in the pi filter. The speaker field is just a load off B+ to ground. It can be left open.
9/17/2013 7:46:12 PMWarren My Error
Did not look at the print for your radio. CV is correct.
