Identical to 01A = 201A = D401A = 201 = ER201A = C509A = C509 = 301A = VT-30 = DC201A = CV750 = 401A
Similar Tubes Other shape (e.g. bulb type):
AX201A; UX-201-A_Japan; UX201A
Normally replaceable-slightly different:
38001; A_Common; C-201A
Other base:
C509_B4
What tubes do you have? CV gave you a list of exact subs. There are similar tubes such as 112A.
Your radio should have standard tube sockets, not requiring the bayonet pin. For that type of socket you could use #30 tubes and reduce filament to 2 volts.
:From radiomuseum.org:
:Identical to 01A = 201A = D401A = 201 = ER201A = C509A = C509 = 301A = VT-30 = DC201A = CV750 = 401A
:Similar Tubes Other shape (e.g. bulb type):
: AX201A; UX-201-A_Japan; UX201A
:Normally replaceable-slightly different:
: 38001; A_Common; C-201A
:Other base:
: C509_B4
