cassette recorder noise
9/14/2013 8:07:15 AMPhilip
I have a Channel Master cassette recorder model 6305 which I can't get a schematic so troubleshooting is difficult. When I play a cassette I get predominant static or steady noise above the recording, music. I can barely hear the recording, music in the background. How can I troubleshoot this? Maybe with an audio signal generator? Is the head defective?
9/14/2013 11:02:06 AMwarren
Check the head adjustments. A bent head mount is common. Record on a blank tape. See how that sounds. If that sounds okay the head is out of adjustment for prerecorded tapes.
9/14/2013 2:19:40 PMBrianC
Keeping it simple...Just look for a bad ground connection on the heads, circuit board, etc...
9/15/2013 8:30:40 AMPhilip
:Keeping it simple...Just look for a bad ground connection on the heads, circuit board, etc...
Thanks Brian C. That's good advice for every technician. I was wondering if you could send me a typical schematic of a cassette recorder showing how the heads are fed to the PCB and a tutorial of how the heads convert the tape to audio?
9/14/2013 3:44:35 PMPhilip
:Check the head adjustments. A bent head mount is common. Record on a blank tape. See how that sounds. If that sounds okay the head is out of adjustment for prerecorded tapes.
Thanks Warren. I'll try that.
