Now to the refinishing (which it needs) but there is an original decal on the front bottom, which I need to protect while refinishing.
Ideas?
As always, many thanks in advance.
Terry F
Another approach might be to take a close-up digital photo with a decent digital camera, then play around with photo-editing software until you get a printable image. Even if the decal is damaged, you can generally "rebuild" it using the photo editor. Hobby shops sell inkjet-printer-compatible waterslide decal film, which is mostly used by railroad modelers and so forth. You can scale your decal photo to close to the original size, then print it off and spray it with a sealcoat of clear lacquer (inkjet ink is water soluble, so this step is necessary for waterslide decals).
The only flaw in this approach is that inkjet printers cannot print "white" at all and can't print metallic tones (such as gold) convincingly. However, this can be worked around with a little extra effort by editing the white or metallic areas of the decal to simply show "clear" or no color at all; then the necessary color(s) can be brush-painted onto the work as a basecoat prior to decal application.
