Any ideas on a 120V conversion?
Tube lineup: UCH 81, UBF 89, UCL 82, UY 85.
PS... It is really interesting taking an old radio through airport security! I was also bringing home an antique clock. They even x-rayed my shoes.
Someone emailed with information about the tubes used in this radio being equivalent to US tubes, using the same voltages, etc. With this info I got brave and checked voltages on the many-tapped power resistor and found that jumpering a couple of taps allowed 120 V to power the radio. Works great!
Thanks all-
Brad
: I have a Phillips European radio with marking MK 36749 on the back and a corner of a missing paper label that probably had a better ID on it. I currently run this radio with an external transformer but I'd like to rewire the radio for 120V if possible (a schematic would probably help!).
: This radio is probably from the 1960's as it uses circuit board and tubes. It uses a big honking resistor with several taps instead of a power transformer. The currently used tap is stamped 240V, an unused tap is stamped 208V. Unfortunately there isn't one stamped 120V...
: Any ideas on a 120V conversion?
: Tube lineup: UCH 81, UBF 89, UCL 82, UY 85.
: PS... It is really interesting taking an old radio through airport security! I was also bringing home an antique clock. They even x-rayed my shoes.
Power it with the transformer, it's the better way and,
depending on the transfoermer, the safer way.
73
Peter DG7BAM
