zenith 9s 262
9/10/2013 11:32:19 AMsmith
zenith 9s262,is missing the eye tube.the wires have been removed .i am installing a new one ,but need to know where the wires go.
9/10/2013 11:49:01 AMCV
What info do you need beyond what the schematic already provides? Are you looking to duplicate the original wiring harness connections/wire routing?
9/10/2013 11:51:49 AMsmith
:What info do you need beyond what the schematic already provides? Are you looking to duplicate the original wiring harness connections/wire routing?
:yes ,all the above,thanks
9/10/2013 12:51:07 PMCV
This link has a good shot of the eye tube harness and where it enters the chassis toward the top rear.
http://www.radiomuseum.org/r/zenith_9s232_waltons_9_s_232_ch5.html
Wiring under the chassis is pretty deterministic: resisor off B+ to the target anode wire; ground wire; wire to the "hot" side of the 6.3 VAC heater bus; and the control grid wire. Four wires total. Don't forget the 1 Megohm resistor inside the socket that provides bias for the triode plate.
