Of course, the problem could be anywhere else in the AM section's RF or IF string... but the ECH81 tube fault is a very common one.
I own this model but haven't needed to work on it for several years, so my memory is a little foggy as to its innards. But I seem to recall that, while the lift-off case was a nice service feature, the jam-packed linear switch array was semi-daunting. Great sounding radio, however, and well worth the effort to repair. Close to the last of the awesome Opus series.
You have a combined AF and DC mix coming from your FM detector section, via the FUCHSIA ARROWED LINE It then reaches a branch where the DC component swings to the left, continuing on as the same GREEN ARROWED LINE of the AM and FM sections. as grid drive for your EM84 eye tubes control grid. 73's de Edd but I've clicked on "Remind me later" 1,887 times.
Sir . . . Brian Ceeeeeeeeeeeeeee
With all of THIS info, how can you now fail in your efforts ?
Here is your signal flow with color coded referencing:
downwards and connecting into # 7
of mode switch UIIb
You have a combined AF and DC mix coming out of the AM detector, via the BLUE ARROWED LINE, its DC AVC
portion component is branching off as the BLUE-RED ARROWED LINE path, while another path with AF and DC
is moving on up to make connection on into # 5 of mode switch UIIb
The rotor of of mode switch UIIb at its # 5 connection, is being positioned in accordance to whether being in its AM
or FM mode, is taking off signal to then pass down the
GREEN ARROWED LINE to pass over to the right and then
downwards .
until it reaches the control grid of the tuning eye tube.
Back at that branch, the AC component continues downward as the GREEN-RED ARROWED LINE , and as the audio input
into # 10 of the St switch.
Thassssit . . . .
As far as the different signal routings, the GREEN ARROWED LINE is importing the negative DC samplings of EITHER
Sooooooooo ...... monitor its DC levels in both the sets AM and FM modes
Now with only the AM not driving the eye tube, one would immediately want to suspicion switch UIIb at its # 5 contact
BUT you said that you HAD AM audio, so it must be connecting . . . . .along with its passing of the DC component.
Sort of makes you want to suspect the detected level / or amplified RF output prior to the detector stage.
Inspect / Meter the possibilities and feedback to us.
I don't think I've done a system update on my computer since 1998,
TELEFUNKEN OPUS 5430MX Schematic:
:Thanks for the help CV...I have some space on the bench to get back to working on this set and try your ideas. It came with only 1 Telefunken (Klangbox) 2402 speaker box..I am looking for another in your travels...
