grounded
9/8/2013 7:08:56 PMron
I got silvertone 4569 c 12 cap leaked out so I replaced with small cap does this need to be grounded right to main radio frame or not old cap had paper ring washers on top and bottom
9/8/2013 7:18:10 PMCV
Wire it like the schematic shows: + side of cap to cathode of rectifier (6X5); - side of cap to center tap of HV winding on power transformer. Do not connect the - side of this cap to chassis or you will have hum.
9/8/2013 7:26:27 PMClifton
Also, completely disconnect the old cap from the circuit. Don't bridge the new cap across the old one.
Clifton
:Wire it like the schematic shows: + side of cap to cathode of rectifier (6X5); - side of cap to center tap of HV winding on power transformer. Do not connect the - side of this cap to chassis or you will have hum.
