Radiola 46
8/29/2013 8:23:50 AMJohn
I have a Radiola model 46 and when I pull out the 80 tube and plug the radio into my dim light tester the light lites very bright. Is this a foolproof sign that the power transformer is shorted?
8/29/2013 8:31:31 AMNorm Leal
John
Yes, most likely the power transformer has shorted turns. In a few cases filament wires in a radio are shorted but this doesn't happen very often. The rectifier socket could also arc over but you should see signs of this.
Use a 60 - 100 watt lamp. A 15 - 25 watt may light even with the 80 pulled.
8/29/2013 8:45:45 AMCV
Not necessarily. Even with the B+ load removed (80 tube pulled) there will still be quite a load on the transformer. If the last set you used your dimbulb tester on was a small AA5 instead of a prehistoric radio like the '46 you may have undersized light bulbs (not enough watts). Why not take a line current reading and see if it is in the ballpark for the set's rated power?
