It sure, kind-of sounds like a silver-mica-disease type problem... if you are experiencing loud crashing static sounds.... like lighting-type static sounds.
Does your chassis use those slug-tuned IF transformers?
I don't believe it did... but there just may have been a production change.
But if your IF cans use the separate cap trimmers then... you have nothing to worry about SMD.
Otherwise ... I can't think of why you'd have steady static and no stations.
The IF frequency for this set is 455 KHz, so if you used 445K to peak the IF transformers, that could cause the set to reject the mixed signal, resulting in no reception.
So 455khz is the difference... right?
So 455khz is the correct freq with which to align the IFs.
Even if a strong modulated 455khz were applied at the ant it can be heard at the speaker and the IFs can be peaked for that.
It's usually applied to the grid of the rf amp/mixer.
Since the IF RC circuits are finely tuned (presumably) to pass only 455 KHZ and reject all other frequencies, if they were passing 445 KHz, something is out of whack. Hence my questions as to whether or not he was actually injecting 445 KHZ, and exactly where it was being applied.
