8/21/2013 8:39:00 PMScooter(108014:0)
Hi all. I have a Philco 90 (two 45 output tubes) and my output tr. is open on both windings. The .7 ohm speaker voice coil has to match up with 6700 ohm impedance of the output tubes. Could someone recommend a replacement that I could purchase?
8/22/2013 11:21:03 AMEisman Freed(108021:108014)
:Hi all. I have a Philco 90 (two 45 output tubes) and my output tr. is open on both windings. The .7 ohm speaker voice coil has to match up with 6700 ohm impedance of the output tubes. Could someone recommend a replacement that I could purchase?
You might find a used one here:
http://www.oldradioparts.com/2a23dfl.txt
Hope that helps!
8/24/2013 3:45:42 PMscooter(108066:108021)
::Hi all. I have a Philco 90 (two 45 output tubes) and my output tr. is open on both windings. The .7 ohm speaker voice coil has to match up with 6700 ohm impedance of the output tubes. Could someone recommend a replacement that I could purchase?
:You might find a used one here:
:http://www.oldradioparts.com/2a23dfl.txt
:Hope that helps!
:Thanks for the suggestion.
