What model number? Measure plate and screen voltages on tubes. Has the radio been aligned?
:I have an aircastle I replaced all the capacitors it powers up good but volume is real real low turned up all the way can it be speaker bad does speaker have amplifier it has two transformer like units on it looks original
::Hi
:: What model number? Measure plate and screen voltages on tubes. Has the radio been aligned?
:::I have an aircastle I replaced all the capacitors it powers up good but volume is real real low turned up all the way can it be speaker bad does speaker have amplifier it has two transformer like units on it looks original
:I'd check alignment also, correct volume control ohms?
Also, by determining that a set works first before wholesale parts replacement is performed, you can cut your time/money investment if your set has a fatal problem like a broken bandswitch or similar catastrophic/hard to repair fault.
