Hello!! I was studying the Hallicrafters S38D schematic the avc line is a negative voltage. My question is: How are the negative voltages produced in the chassis? Thank You!! Daniel
8/19/2013 4:24:28 PMCV(107973:107972)
http://www.radioremembered.org/detector.htm
8/19/2013 4:41:36 PMNorm Leal(107974:107973)
Just a quick comment. Radio picks up a signal. It's amplified. The detector then rectifies it to generate a negative AVC voltage. Stronger a signal greater negative AVC voltage.
