Dean
Dean,
When making a replacement probe it would be a lot easier (from a construction stand point) to place the 1 Meg resistor inside VTVM at the selector switch. Is there any real advantage to having the resistor in the probe?
Greg
Yes, absolutely: it isolates the probe capacitance from any RF circuitry you're measuring. John F. Rider got a patent on that idea.
The rectifier can be replaced with a single silicon diode with a PIV of at least 200 volts, and 1 amp. I usually use 1N4003's. Digi-key has been a good source for them in the past.
If by chance you have a full wave unit,it will have 4 terminals, either use 4 of the above, or use a bridge rectifier of the same parameters as the single diode above.
: I was recently given an EICO 232 VTVM in good condition,
: minus the probe. Is there anything special about the
: probe used (resistance?) or will any test lead suffice?
: I want to replace the selenium rectifier before I power
: it up; can anyone suggest an equivalent silcon bridge rectifier
: or diode combination to use? I have downloaded the
: manual and service bulletin from this site and can
: begin refurbishment/calibration when I get this info.
: TIA
