:Take a look at the tuning indicator stringing info for this set (under Resources) and verify that the set is correctly strung. It's easy to get the string misplaced so it "wraps over" on itself and binds up when turned in one direction or the other. This isn't rocket surgery to fix but requires a fair amount of patience to get perfect the first time you have to do it for a given set type. Just follow the instructions and you'll be OK.
CV
I don't see much info on the brass dial cable. I have it in the correct path. Should this cable be greased a little? Seems like the spring doesn't keep it tight enough.
John
