If you can provide the make/model of the set that you are contemplating changing, users of this forum can give you more detailed information on the conversion process.
PS: Keep the metal core installed inside the field coil.
:Thankyou for your prompt reply cv. The radio is a Charlie McCarthy no 1, parts a bit hard to find down under. The speaker cone is too far gone.
:Regards
:Alan
On the next picture, the field coil has been installed (silicone glued) over the PM speaker.
PS: Be carefull to the magnetic pole. When the field coil is energized, it should be attracted by the Permanent magnet pole.
:Regards
:Alan
I forgot to tell that when i'm forced to install a PM speaker, i usually get rid of the humbacking coil.
There are places that can recone speakers. It can be expensive though. I had a electrodynamic speaker reconed for a Webster-Chicago wire recorder just to keep it all original.
Clifton
:Great idea Vianney I will do as you suggest
:Regards
:Alan:
But it seems to me that there should be a higher standard for pop-culture and historically significant models. Don't want to wax too philosophical here, but at what point do we stop treating these units as techological/hobby hardware curosities and begin to regard them as important cultural icons over which we merely have stewardship?
