Rebuilding IF cans
8/10/2013 10:43:14 PMDaniel M. Rine
Hello!!
I have finished recapping a Hallicrafters S38D chassis. There is a lot static on every band when tuning. I think the problem is the capacitors in the IF cans. Can someone point me to a web site that can explain how to do this procedure?
Thank you!!
Daniel
8/10/2013 11:42:43 PMBrianC
Are you asking about rewinding the coils, or just replacing the caps in the cans...???
8/11/2013 8:57:03 PMDaniel
:Are you asking about rewinding the coils, or just replacing the caps in the cans...???
:I am wanting to replace the capacitors.
8/11/2013 3:03:38 AMCV
http://www.ppinyot.com/if_transformers.htm
8/11/2013 1:43:05 PMClifton
Daniel,
Is the static present all the time or just while actually turning the tuning knob. The grounding strips between the tuning capacitor rotor (movable part) and the capacitor frame may need to be cleaned if there is noise while tuning.
Clifton
:Hello!!
: I have finished recapping a Hallicrafters S38D chassis. There is a lot static on every band when tuning. I think the problem is the capacitors in the IF cans. Can someone point me to a web site that can explain how to do this procedure?
:Thank you!!
:Daniel
