It only has static coming out of it now. I've been all over it and can't find a problem. No bad caps, resistors etc. Nothing fried. All the voltages look good. I even threw a new set of NOS tubes in it that I had even though the ones in it tested good.
I remember having a problem with this set when I first built it. I had to clean the Loctal tube pins and sockets VERY thoroughly before it would work right. I've done all that again and still just static.
Hope I remembered how to link the schematic here. It comes from the "Resources" page here at NA. Haven't been working on a lot of radios now that I'm fully into the '65 Ranchero restoration. If you have any ideas I'd sure like to hear them. Thanks,
Johnny
What's the "Green Dot" problem Warren?
Johnny
Johnny
So what caused it? Through the process of elimination I found that disconnecting B+ from the RF section of the radio stops the 1K resistor from heating up. This sucks!
If you've ever taken apart the RF section of a Philco 46-480 you know what I mean. It's a bear. I checked every component I could get to and I don't see anything wrong. BUT! There's a ton of stuff buried in the bandswitch that one just can't get to without taking the bandswitch out. This is a terrible job on this radio but I know where the problem is and now I just have to tear it apart and find it.
Johnny
Awfully prescient of those Philco engineers to put that 1K resistor there, I'd say.
I'll try to post a picture of this RF section later. I'm confident my problem is in this section. I disconnect that B+ line from the RF section and my excessive current draw on R17 goes away.
Johnny
Now, that statement makes no sense if in fact R17 is the resistor that got fried, as you earlier reported. R17 will only cook if excessive current passes through it. That can only happen if something on the its C37 side is a low impedance to ground. A short anywhere else on the other (B+) side of R17 can not possibly damage R17.
Your statement about the wiring in the IF cans being new is a clue. An errant wire strand inside the can on the primary side of the transformer can wreak all sorts of havoc.
