MYSTERY PHILCO!!!
2/2/2002 12:21:54 PMBrad
The mystery Philco has the following tube lineup:
6K7
5Y4G
6V6
6A8G
6Q7G
It is in a wood tombstone cabinet, is AM/Shortwave, tubes and speaker rot says it must be from the 30's. I'm trying to dig up a schematic, and figure out the can caps-
The radio has the following one tap can capacitors with Philco numbers only:
30-2024S
30-2117S
30-2118S
Any ideas on the MFD values? Philco model #?
2/2/2002 2:45:03 PMNorm Leal
Hi Brad
Philco made several models with similar tube lineup around 1938. The 6V6 could have been a 6F6. They are usually interchangeable.
Check schematic for 38-60 or 38-610 on this site.
Chuck Schwark has a Philco site with cross numbers for parts. Your caps should be listed there.
http://members.aol.com/philcodata/pdatindx.htm
: The mystery Philco has the following tube lineup:
: 6K7
: 5Y4G
: 6V6
: 6A8G
: 6Q7G
: It is in a wood tombstone cabinet, is AM/Shortwave, tubes and speaker rot says it must be from the 30's. I'm trying to dig up a schematic, and figure out the can caps-
: The radio has the following one tap can capacitors with Philco numbers only:
: 30-2024S
: 30-2117S
: 30-2118S
: Any ideas on the MFD values? Philco model #?
2/3/2002 10:12:08 AMBrad
Norm-
You've done it again- The radio matches the picture and diagrams for a Philco 38-60, with one replacement tube as you mentioned. I now have schematics and got the radio working too.
Thanks again-
Brad
: Hi Brad
: Philco made several models with similar tube lineup around 1938. The 6V6 could have been a 6F6. They are usually interchangeable.
: Check schematic for 38-60 or 38-610 on this site.
: Chuck Schwark has a Philco site with cross numbers for parts. Your caps should be listed there.
: http://members.aol.com/philcodata/pdatindx.htm
: Norm
: : The mystery Philco has the following tube lineup:
: : 6K7
: : 5Y4G
: : 6V6
: : 6A8G
: : 6Q7G
: : It is in a wood tombstone cabinet, is AM/Shortwave, tubes and speaker rot says it must be from the 30's. I'm trying to dig up a schematic, and figure out the can caps-
: : The radio has the following one tap can capacitors with Philco numbers only:
: : 30-2024S
: : 30-2117S
: : 30-2118S
: : Any ideas on the MFD values? Philco model #?
