:Hello All,
: I have the service data for this radio. It's in AR-58. When I touch a screwdriver to the collector of Q1, the reception is a lot stronger. If I touch the antenna input or the base of Q1 (secondary of L1) the signal gets weaker.
: Very weak stations are almost inaudible (unless I touch the collector of Q1 with a screwdriver). It's difficult to say whether this problem is the RF amplifier (Q1), or something in the AVC line. The Base voltage of Q1 is about 1.2 volts, which is a little high, almost twice what it's supposed to be. The emitter voltage is supposed to be .1 volts but it's 0 volts. The collector voltage is 10 volts, which is correct.
: This is a puzzle. Q1 is a DS-71 (ECG107).
: Please help if you can.
:Thanks,
:Dave
