Pull the rectifier tube and power the set up. Does the transformer still growl?
Methodically examine each circuit branch that draws current off the B+ source node and you will discover what is drawing excessive current. There are only a few possibilities in a simple set like this. Don't be afraid to cut/unsolder/lift wires to isolate the problem. To state the obvious, limit the set's "on time" while doing this investigation to avoid fatally cooking the power transformer. Most sets aren't terribly robust when overloaded.
If the radio didn't growl before the recap, my money would be on a connection flub or solder splash. I understand that you may not have wanted to power up the set before recapping it out of fear of damaging it, but doing so may give good info if you can do it safely (i.e., with a Variac or dim-bulb rig). (For future reference only.)
If the B+ draws normal current (somewhere in the neighborhood of 80 mA, more or less) but the transformer still overheats/growls, you may have a bad power transformer. Stuff happens. To paraphrase Forrest Gump, antique radios are like a box of chocolates: you never know what you are going to get. A bad power tranny may have been why the set was retired, several decades ago. I hope not.
My preference with an old radio is to first bring it up on a variac to see if it works. If not, I will troubleshoot and get it working, after a fashion, before wholesale recapping. Then, after each cap is replaced, check to see that the set is still working.
:Working on a gilifillan t4 trf. I did a recap and the radio works no hum. The transformer is a blistering fire hazard. The power supply has a loud hum, almost sounds like a consistent electrical arc. Any ideas?
