Some have a wafer under the eye tube that can be pried out. It can also be pushed out from the back.
If your socket has a metal cover it will pry off with a screw driver.
:Hey, guys. Any tricks to get the eye tube socket apart? I can't tell if I should just try to pry the metal case away from the plastic socket or do I need to turn it first or is there some other way this is done? Thanks. Mark from Kalamazoo
