Here is a list of radios using those tubes:
http://www.grillecloth.com/sylvania/tubelist.php?pageNum_rsRecordset=0&totalRows_rsRecordset=22&comp=&mod=&Num=4&tube1=6c6&tube2=6d6&tube3=38&tube4=12z3&ball=&Submit=Submit&db=5
:Hi Robin, you wouldn't happen to know the model number on the radio? Thanks, George T
:George T,
:Like many this age the only name is on the plate on the front. It is the same logo as some seen elsewhere on the web. The only other number is the pressed-in part number on the chassis.
Hey, Norm!
I've looked all these over and noticed a few differences. My set has a switch on a coil on the back that maybe for BC/SW. Mine also has two pilot lights. I can't find a schematic for the Fada 110 A or B, though.
I looked up the tube substitution and the 6C subs for a 77 and the 6D6 subs for a 78. When I checked these out several models came up and there are schematics in Ryders for them.
Copy and paste:
http://www.grillecloth.com/sylvania/tubelist.php?comp=&mod=&Num=4&tube1=12Z3&tube2=38&tube3=77&tube4=78&ball=&Submit=Submit&db=5
:Maybe one of these schematics will work.
Bob Masse
