Freed NR-6 wire connection question?
6/18/2013 6:00:43 PMMitch
Hello everyone,
I am using the schematic from here, NA. I am wiring this radio as most of the original wiring was missing.
I do not think that the schematic is correct with the +45 volt circuit. If you trace the circuit it goes to a junction eventually connecting to the Battery Setting 6 volt input to the + side of the filaments.
I do not think this is correct.
Does anyone have a schematic that shows something different or can answer as to how this supply should be wired?
Information and solutions appreciated.
email posted
Mitch
6/18/2013 6:06:41 PMMitch
:Hello everyone,
:I am using the schematic from here, NA. I am wiring this radio as most of the original wiring was missing.
:I do not think that the schematic is correct with the +45 volt circuit. If you trace the circuit it goes to a junction eventually connecting to the Battery Setting 6 volt input to the + side of the filaments.
:I do not think this is correct.
:Does anyone have a schematic that shows something different or can answer as to how this supply should be wired?
:Information and solutions appreciated.
:email posted
:Mitch
6/18/2013 6:23:05 PMBill G.
Hi Mitch,
The schematic looks OK.
The thing that is throwing you is that the 6 volt positive is common with the negative of the 45 volt supply.
The negative of the 6 volt battery is distributed to the filaments through a variable resistor.
Best Regards,
Bill Grimm
