:You are missing the audio output tube. A 3V4 would be my guess.
http://www.nostalgiaair.org/PagesByModel/594/M0017594.pdf
You're missing the 50Y6GT.
Bob Masse
With Silvertone chassis numbers it sometimes works with the period in the number and sometimes it works better without it. Sometimes substituting Sears for Silvertone helps also.
Bob Masse
:http://www.google.ca/#sclient=psy-ab&q=silvertone+110.411&oq=silvertone+110.411&gs_l=hp.12...3848.3848.1.4958.1.1.0.0.0.0.211.211.2-1.1.0.ernk_timepromotionb..0.0...1.1.17.psy-ab.WQQuQs_Amec&pbx=1&bav=on.2,or.r_qf.&bvm=bv.47883778,d.aWM&fp=f4b558c1a72f951f&biw=1440&bih=744
:With Silvertone chassis numbers it sometimes works with the period in the number and sometimes it works better without it. Sometimes substituting Sears for Silvertone helps also.
:Bob Masse
Thanks, Bob. I wish to add that 50Y6 would be the rectifier. So would that radio work well with a silicon diode substituted for the 50 volt tube?
http://www.tubesandmore.com/products/T-50Y6GT
Bob Masse
I believe that Sears chassis had the tube lineup of 1A7GT, 1N5GT, 1H5GT, 1A5GT & 50Y6GT. I believe the 1T5GT is/was an acceptable substitute for the 1A5GT output tube.
Clifton
:I have this Sears Silvertone portable and it is missing a tube. The other tubes are 1A7, 1N5G, 1H5, and 1T5. What would the other tube have been? The only numbers on it are 110.411 but I don't find that number listed anyplace.
Carl T
