Thanks, Len
No, something's not right, shouldn't be any change. Could have wires that are barely holding on. What is the ohm measurement when you touch the field coil vs. when you don't? What is the spec resistance of the coil (if you have that info.)
If this coil was totally open what effect would it have on the voice coil and chassis.
Thanks, Len
This is not normal and indicates that you have a corroded section of wire in the field coil. Since it is sensitive to mechanical pressure on the cover paper, it's possible that the problem is in an outer winding layer. You could try carefully removing the paper cover, then examine the visible windings to see if there are discolorations or burnt areas. Damaged windings could be stabilized with transformer dope; but this is a long shot. The "course of least resistance" would be to locate a good replacement speaker on eBay or some other radio-trading venue.
Thanks, Len
It will probably work OK as is. The new resistance is only 8% low.
What type of tape can I use to wrap around the coil to hold it all together, it was the original tape that corroded the wire and caused the short.
Thanks for the help.
You might want to make a paper sleeve that goes around the coil. Overlap and tape the ends together. That way the tape adhesive doesn't contact the wire. Then you can throw an outer layer of whatever decorative tape you want (I've used black duct tape for this purpose) over this paper layer for additional protection if you want. This will prevent the paper from falling off if the taped joint gets warm enough to cause the tape adhesive to lose its grip.
