Further indications:
i) the ticking starts to occur after the set begins to warm up. The station audio is heard, and then the ticking begins after about 20-30 seconds.
ii) the sound is less obvious on weaker signals. The more powerful the station, the more intrusive the noise.
Head Scratching:
i) Do you think this could be caused by a 'noisy tube'; one which tests OK (they all do), but has a fault which isn't shown on my tester. As someone used to say to me, 'your radio is your tube tester'...
ii) If it could be a tube with a short, which would be the likely villain? V107 (for example)?
iii) I've turned my eyes inside out looking for any loose wires, though the 'ticking' doesn't sound like that, and no moving the set around will change the nature of the 'ripple'.
iv) would there be any sense in changing out all the electrolytics just in case? I'll reconnect C148 and C156 as they seem to fine and 'if it ain't broke, don't fix it'.
Thanks for all your help, Sir Edd, and I hope I can get to the bottom of this gremlin before the Scott is put to gather dust at the back of my workshop as one of those sets requiring an exorcism...
Cheers,
Leslie
PS Hi Edd how ya bin doin?
I'll give it a try but this particular set is so beautifully built and (inside at least) in mint condition I'm reluctant to start a wholesale electrolytic purge. I'll try changing them out one at a time. It would be nice to change them in order of 'likely villains' though...
Cheers,
Leslie
I do have a tester, though I tend to use it just for resistors rather than capacitors (either electrolytic or non-electrolytic). I could have a go and see what happens, though when I've tried to use it for capacitors the values seem different each time apply the leads.
Can you test electrolytics while they're still connected to the circuit in the radio, or do you have to cut the wires and then test them?
Cheers,
Leslie
Have you tried moving the radio to another location? Or even taking it to a friend's house for a trial? I'm thinking your radio is sensitive, MAY be picking up external noises from electronic everything from light fixtures, alarm systems, fancy toasters, etc.
I haven't tried the set in other places, but I've got numerous radios, including some very sensitive military 'boatanchors' and in my workshop (attached to the loaded whip antenna I have on the roof) none of them have this noise (kind of like a random series of bass 'ticks', not scratchy like a loose wire or bad connection).
I was wondering if it could be a faulty audio amp tube (perhaps); all the tubes test fine on my vintage tester, but I know that sometimes a tube that tests ok can have shorts. In this case, the noise does not start until about 30 seconds after the set has warmed up and a broadcast signal can be heard.
Anyhow, thanks for the suggestion.
Cheers,
Leslie
PS: I've also found that LED lights are great RF noise generators, along with toasters et. al.
