Steve
This would be an interesting project, but there are many factors you should consider.
First, the series string tubes all need to match as far as their heater current requirement is concerned.
A heater string including a 12SA7 will be intended to run at a nominal 150mA. All the tubes will be rated at this current. Power tubes run at increased heater power by dropping a higher voltage, thus a 50L6 or 35Z5. Most common signal tubes for series string radios use 12.6V rated heaters, as this provides them enough heater power to do their jobs at 150mA.
The proposed 6SA7 and 6SK7 types require 300mA heater current. So they can't just be added to the existing 150mA string.
There are a few signal tubes with 6.3V 150mA heaters. These may not be drop-in replacements, but you might get them to work OK in your radio. The loktal tubes, 7A8 and 7B7 might be made to work in place of the 12SA7 and 12SK7. There may be octal and miniature tubes that have the lower heater power requirement, as well. he lower power tubes generally have somewhat lower gain than the otherwise similar full-power tubes.
But before you start this project, there are other issues to ponder.
A main advantage of an RF stage is added selectivity ahead of the mixer. But to get this, the RF stage requires an additional tuned circuit. That is normally done using a third gang on the tuning capacitor. Adding another capacitor gang to your existing radio would not be a trivial undertaking. If an RF stage is added without the extra tuned circuit, it will do nothing for selectivity, and won't even add much gain, even less as the frequency is increased.
I wonder if your best bet is not to make a separate pre-selector to go between the radio and the antenna. This way the radio could be kept original, with no risky modifications to it.
A pre-selector could be housed in a separate box, with a dial and knobs on the front, and be powered from the AC line, or even a battery. No need to be debugging a hot chassis.
The pre-selector could have from one to three tuned circuits at the RF frequency, and possibly an RF amplifier stage to boost the signal. You would have to learn to tune using two knobs, as the pre-selector would have its own tuning knob. The gain stage could use a tube, one or more transistors, or an IC.
Another possibility would be to add a Q-multiplier on the radio's antenna tuning circuit. This could give you much of the benefit an RF stage would provide, but would not require keeping two tuning knobs synchronized.
If you want a real project, you could add all sorts of stuff driven by a microprocessor. An analog output could drive varactor diodes that would allow any additional tuned circuits to track the existing tuning capacitor. It could provide a digital frequency readout, and all sorts of other fancy stuff. You could even use it to stabilize the radio's local oscillator frequency. This would not be a trivial project, but if you are trying to find something to do with your new Arduino, it could keep you busy.
Ted
Thanks for Your Comments,
Steve
Steve
Steve:
Think of it like this: The filament of the tube has to be a certain number of Watts...by Ohm's law, 12 Volts at .150 Ampere is the same number of Watts as 6 Volts at .300 Ampere, but the number of Ohms has to be different. So, if you try to replace a 12 Volt tube with two 6 Volt tubes in a series circuit, you are going to get some very bright tube filaments, and some very dim ones. The current in a series string has to be the same for each element in the string. The Voltage can be different, as in 50L6 and 12SK7...different Voltages, but same current.
Lewis,
If I do the six tube filament string, with two 6.3 tubes and retain the two 12SK7s, the 50L6, and the 35Z5, and apply the 120v across the string,
is the voltage drop across each filament established by the filament resistance?
Steve
:::Steve, the series filament tube complement should add up close to 120 volts, your AC line voltage. If you put two 6 volt filament tubes in, you will change the voltage drop across the whole tube complement causing too high voltage and current in the tube filaments.
:::Those two tubes will work but, you will need to put a proper dropping resistor(ohm value and wattage in series with the tube filaments.
:::C Harris
::C Harris,
::I was thinking of replacing the 12SA7 converter with a 6SA7, and adding a 6SK7 RF stage, so that the total voltage drop along the 6 filament string would be the same as the the drop along the original 5 filament string. But, I had a look at the datasheets and the 6.3v tubes require 300 mA, whereas the 12.6v tubes require 150 mA. So, the substitution probably won't work because I don't want to run 300mA through the four original tubes that would remain in the six tube scheme.
:: Thanks,
:: Steve
:Steve:
:Think of it like this: The filament of the tube has to be a certain number of Watts...by Ohm's law, 12 Volts at .150 Ampere is the same number of Watts as 6 Volts at .300 Ampere, but the number of Ohms has to be different. So, if you try to replace a 12 Volt tube with two 6 Volt tubes in a series circuit, you are going to get some very bright tube filaments, and some very dim ones. The current in a series string has to be the same for each element in the string. The Voltage can be different, as in 50L6 and 12SK7...different Voltages, but same current.
:Lewis
This thread seems to have strayed off topic, so I'll cut to the chase:
No, you can't successfully make the change that you are proposing. A series-string set must have tubes that all draw the same amount of current; in the case of the S-38's complement, this is around 150 mA. The 6SK7/6SA7 draw 300 mA.
You can think of each tube as a resistor, calculate its equivalent resistance from its spec, then use that info to play electronic design "what-if" games. The equivalent resistance of any tube will not change from application to application. The amount of current it draws, or the voltage it drops, will.
For the S38 lineup, here are the equivalent resistances for a line voltage of 120 VAC:
50L6: Req= 50/.150 = 333 ohms
35Z5: Req= 35/.150 = 233 ohms
12xxx: Req= 12/.150 = 80 ohms
6xxx: Req= 6/.300 = 20 ohms
So, for a "stock" S38, you have one 50L6 tube, one 35Z5 tube, and three 12xxx tubes in series. This is 333+233+(3*80)= 806 ohms.
Using Ohm's Law, E=IR, and I= E/R, or 120 V/806 ohms= 148 mA.
Again using Ohm's Law, the voltage "seen" by each individual tube will be as follows:
50L6: Req * Istring = 333*0.148 = 49.34 V
35Z5: (same) = 233*0.148 = 34.48 V
12xxx: (each tube) = 80* 0.148 = 11.84 V
So, all is well in S38-land if the correct tubes are used. What if we sub two "six volt" tubes for one of the 12xxx, as proposed?
First, we recalculate the string current:
333+233+80+80+20+20 = 766 ohms (from the above Equivalent Resistance calculations). 120 V/766 ohms =
0.156 amps.
The voltages across each tube in the new string would therefore be:
50L6: Req * Istring = 333*0.152 = 50.6 V
35Z5: (same) = 233*0.152 = 35.4 V
12xxx: (each tube) = 80*0.152 = 12.6 V
6xxx: (each tube) = 20*0.152 = 3.0 V
So, while the "original" tubes in the string would not be damaged by such a modification, the heaters of the "new" 6xxx tubes would be power starved and unable to emit sufficient electrons to operate properly.
Thanks Again,
Steve
A major complication is the bandspread cap: in the S-38, the main tuning and the bandspread variable caps are both 2-section units. In the NC-57, which has an RF amp stage, they have to both be 3-section units.
I did try out an IF transformer which I extracted from my GE Model 321 junker. On the primary side, with the secondary open, I saw the expected resonant peak around 455 kHz. Would the S-38, even at the same 455 kHz, need a something less ordinary?
Steve
I was given an old N-57 this spring for free. I restored it and can hardly believe how good the RF gain is. It does use the 6SG7 in the RF gain stage. C Harris
Yes, I restored a NC-57 several years ago and it's a decent performer. Very sensitive/selective and stable compared to "living room shortwave sets", plus it has a real BFO, unlike the odd IF-feedback kluge used in the S-38 design. It's been awhile since I've worked on it, but I seem to recall that it was a snap to troubleshoot but somewhat tedious/fussy to align- but maybe that's just a subjective impression on my part. I removed the tiny front-mounted speaker from mine and installed an S-meter in its place, purchasing a separate National metal-box speaker that was intended for use with a higher-end set of theirs.
As nearly as I recall, I scoured eBay until I found a circa-1940's NOS DC milliammeter gauge that was suitable. (It didn't take a lot of searching.) I think that the one I used was 1 mA full scale. This was installed in series with the RF amp's plate and is bypassed by a multi-turn potentiometer (1000 ohms, I think- can't recall what I used- may have been a lower value). It works on the principle that an RF amp tuned to resonance has minimum DC plate current at the resonance point. To "calibrate" the meter, you detune the set with the antenna input grounded, then adjust the pot until the meter achieves full-scale deflection (The idea is for most of the plate current to bypass the meter via the pot, with just enough getting through to drive it to 100% of scale deflection). Then, you reconnect the antenna, and tune a station. The stronger the signal, the further toward zero the indicator dips.
A reverse-reading guage was what I was actually looking for, since I believe that is what the factory option unit uses, but those seem to be hard to find (at least on eBay).
I have to admit that this gauge is of low utility, at least to me. About the most useful thing it does is provide visual confirmation that the antenna trimmer control is peaked. But, it looks cool and, as we all know, that's the main thing.
Since B+ is present on both terminals of the meter, I made certain that the the "mod" was well insulated (and HIGH-VOLTAGE labeled) to give a future owner fair warning.
I was incorrect about the monitored tube- it is actually the 2nd IF amp plate that is being measured, not the RF amp plate current. And the bypass potentiometer is 50 ohms, not 1000.
It is much more practical to monitor the 2nd IF stage plate current than that of the set's RF amp, since the frequency is so much lower than that of the incoming antenna RF. However, the operating principle is the same.
Steve
Thanks Again,
Steve
Steve
http://www.wa2ise.com/radios/12ba7.html
