LOOKING FOR AN AM SCALE (55-150) THAT I CAN COPY TO A CLEAR SHEET OF COPY PAPER ?
5/26/2013 1:42:58 PMK Mantz(106699:106698)
:LOOKING FOR AN AM SCALE (55-150) THAT I CAN COPY TO A CLEAR SHEET OF COPY PAPER ? :
For what? There are only about 14 squidrillion AM scales out there, circular, sliderule, and drum types included. Specifying exactly what you need would slightly improve your chances of actually getting something that would be useful to you.
5/26/2013 6:15:10 PMCHIP(106713:106699)
::LOOKING FOR AN AM SCALE (55-150) THAT I CAN COPY TO A CLEAR SHEET OF COPY PAPER ? :: : :For what? There are only about 14 squidrillion AM scales out there, circular, sliderule, and drum types included. Specifying exactly what you need would slightly improve your chances of actually getting something that would be useful to you. : OK; SLIDERULE TYPE APX 1" HIGH AND 7"1/4 LONG ?
5/26/2013 7:42:48 PMJimmE(106716:106713)
Check with Radio Shack.
5/26/2013 9:55:09 PMDennis Wess(106718:106698)
Here's a few that you might be able to modify to suit. RIGHT CLICK and SAVE AS:
5/27/2013 1:55:13 PMChip(106730:106718)
:Here's a few that you might be able to modify to suit. RIGHT CLICK and SAVE AS: : : : : OK: I scan the scale and run it thru photo shop and the color does print on stock used for over head projectors, would you happen to have some scale's for FM band ? : : : : :
5/27/2013 1:57:37 PMchip(106731:106730)
::Here's a few that you might be able to modify to suit. RIGHT CLICK and SAVE AS: :: :: :: :: OK: I scan the scale and run it thru photo shop and the color does print on stock used for over head projectors, would you happen to have some scale's for FM band ? :: :: :: :: :: : : Using photo shop the color does print using stock for overhead projectors, would you also happen to have FM scales?
5/27/2013 3:06:55 PMDennis Wess(106734:106731)
Here's a few I located on the web. I'm sure there are lots more out there. GOOGLE is your friend. . . . . . .
5/27/2013 5:35:47 PMchip(106739:106734)
: would you also happen to have FM scales? : :Here's a few I located on the web. I'm sure there are lots more out there. GOOGLE is your friend. :. :. : :. :. : :. :. : : : OK: Thank you so much for the scales, and sorry for all the trouble , But what I actually would like is a Matching Set of Am and FM dial scales , my set has fm at the top and am at the bottom(in a square) ?
5/27/2013 8:04:31 PMDennis Wess(106742:106739)
QUOTE: "OK: Thank you so much for the scales, and sorry for all the trouble , But what I actually would like is a Matching Set of Am and FM dial scales , my set has fm at the top and am at the bottom(in a square) ?"
What I've posted is all that I have....suggest you do a websearch for the dial scale you need. :
5/26/2013 9:58:40 PMDennis Wess(106719:106698)
You've got my curiosity up as to how you plan to print white or light colors on clear print stock ?
5/29/2013 8:32:03 PMchip(106779:106719)
:You've got my curiosity up as to how you plan to print white or light colors on clear print stock ? : Thanks for all your help
