Freed Eisemann NR6
5/23/2013 9:29:19 PMMitch
Hello,
Has anyone worked on one of these or would anyone know if the long pin 01A tubes will fit in it, or the short pin tubes only. I get confused over UV and UX.
Thank you,
Mitch
5/24/2013 12:08:33 AMNorm Leal
Mitch
Long (UX) or short (UV) pin tubes will fit. Short pin tubes were original for twist type sockets. When long pins came out they would still fit into these sockets. Bayonet pin was arranged so height was correct. Short pin tubes will not work in standard plug in type sockets.
:Hello,
:Has anyone worked on one of these or would anyone know if the long pin 01A tubes will fit in it, or the short pin tubes only. I get confused over UV and UX.
:Thank you,
:Mitch
5/24/2013 5:12:23 PMWarren
To make this simple, you can use 01A short or long pin in this radio.
5/24/2013 6:00:27 PMMitch
:To make this simple, you can use 01A short or long pin in this radio.
Thank you gentlemen.
5/26/2013 12:59:56 PMWarren
Here is a link for saving 01A tubes. This wafer can be used with other working tubes. Advantage is low current draw. Simulates a triode tube well.
http://bensradioattic.com/item.htm?radio=1020645
