5/12/2013 5:10:59 PMchip(106479:0)
Can some one help me with finding a replacement decal for my am/fm glass plate? It measures 3"x 8" and at the top is the (FM scale 88-108) and at the bottom is the {AM scale 55-160}. I am told that some one has put a dvd out with some of these decals and you can copy the one you want, and transfer and print it out on a clear sheet of special copy paper ?
5/12/2013 7:09:21 PMBrianC(106480:106479)
It would help all concerned if you could give the brand and model # of the radio to start things going.
5/12/2013 9:27:18 PMchip(106482:106480)
:It would help all concerned if you could give the brand and model # of the radio to start things going.
ok this is a tv/phono model 10tz
5/12/2013 9:28:04 PMCHIP(106483:106482)
::It would help all concerned if you could give the brand and model # of the radio to start things going.
:ok this is a tv/phono model 10tz
BRAND - GAROD
5/12/2013 10:35:08 PMGeorge T(106485:106483)
:::It would help all concerned if you could give the brand and model # of the radio to start things going.
::ok this is a tv/phono model 10tz
: BRAND - GAROD
Hi Chip, if it is water slide decals you want Radio Daze carries all kinds of them. One thing though once you put them on it is important that you hit them with a light coat of clear paint or the first time you wax it they will come off. Best 2 U, George T
5/13/2013 8:10:43 PMchip(106493:106485)
::::It would help all concerned if you could give the brand and model # of the radio to start things going.
:::ok this is a tv/phono model 10tz
:: BRAND - GAROD
:Hi Chip, if it is water slide decals you want Radio Daze carries all kinds of them. One thing though once you put them on it is important that you hit them with a light coat of clear paint or the first time you wax it they will come off. Best 2 U, George T
OK: I did some checking and did not see any decals with am/fm scales
5/14/2013 12:52:40 AMGeorge T(106500:106493)
:::::It would help all concerned if you could give the brand and model # of the radio to start things going.
::::ok this is a tv/phono model 10tz
::: BRAND - GAROD
::Hi Chip, if it is water slide decals you want Radio Daze carries all kinds of them. One thing though once you put them on it is important that you hit them with a light coat of clear paint or the first time you wax it they will come off. Best 2 U, George T
:OK: I did some checking and did not see any decals with am/fm scales
Chip, is it you have a dial scale with no scale on it just the glass? A lot of times if you wipe off a dial scale the lettering will come off. Got to be very careful of that. I don't think you will fine a decal to replace the original lettering. Look at Radio Daze and look at the Acrylic and glass dial scales. You might find it there. Good Luck, George T
