Clarion AC-60 Chokes and Input Transformer
5/11/2013 10:37:49 AMByron Taylor
Does anyone know the specifications for the following components? :
1. Choke L2 which connects to primary of input transformer:
a. DC resistance and Inductance(Henrys)
2. Input Transformer to Push-Pull Circuit:
a. Primary and secondary impedance
b. Primary and secondary DC resistance
5/12/2013 10:32:13 AMTom McHenry
:Does anyone know the specifications for the following components? :
:1. Choke L2 which connects to primary of input transformer:
: a. DC resistance and Inductance(Henrys)
:2. Input Transformer to Push-Pull Circuit:
: a. Primary and secondary impedance
: b. Primary and secondary DC resistance
The entry on this site under Resources for "Clarion/60" gives the DC resistances for these parts.
For the audio interstage coupling transformer, it will probably be 1:1 so the input characteristics will determine the impedance of both windings. Basically you are matching the plate circuit of a type 24 tube. I don't know what this is offhand, but it is probably in the several Kohm range; maybe even over 10K. Presumably this can be determined from a Type 24 tube datasheet.
The L2 inductor impedance (DC resistance: 2K) would have been selected to work with the two electrolytic caps in the "pi" filter circuit to have a network impedance peak at around the full-wave rectified DC pulse frequency, which is 120 Hz for North American power. This provides maximum hum suppression. You can calculate this from the impedance equation for a CLC pi network with a center frequency of 120 Hz. My guess is that it will be a couple of Henries.
Sorry to provide mostly "soft" information but I suspect that hard data on these impedance parameters will be difficult to come by. You may luck out and find a restorer who has actually measured the values of these parts, but that's probably a long shot.
5/12/2013 10:35:57 AMTom McHenry
::Does anyone know the specifications for the following components? :
::1. Choke L2 which connects to primary of input transformer:
:: a. DC resistance and Inductance(Henrys)
::2. Input Transformer to Push-Pull Circuit:
:: a. Primary and secondary impedance
:: b. Primary and secondary DC resistance
:The entry on this site under Resources for "Clarion/60" gives the DC resistances for these parts.
:For the audio interstage coupling transformer, it will probably be 1:1 so the input characteristics will determine the impedance of both windings. Basically you are matching the plate circuit of a type 24 tube. I don't know what this is offhand, but it is probably in the several Kohm range; maybe even over 10K. Presumably this can be determined from a Type 24 tube datasheet.
:The L2 inductor impedance (DC resistance: 2K) would have been selected to work with the two electrolytic caps in the "pi" filter circuit to have a network impedance peak at around the full-wave rectified DC pulse frequency, which is 120 Hz for North American power. This provides maximum hum suppression. You can calculate this from the impedance equation for a CLC pi network with a center frequency of 120 Hz. My guess is that it will be a couple of Henries.
:Sorry to provide mostly "soft" information but I suspect that hard data on these impedance parameters will be difficult to come by. You may luck out and find a restorer who has actually measured the values of these parts, but that's probably a long shot.
BTW, I apologize for conflating "inductor value" with "inductor impedance" in the above text.
5/14/2013 8:39:09 PMByron Taylor
:::Does anyone know the specifications for the following components? :
:::1. Choke L2 which connects to primary of input transformer:
::: a. DC resistance and Inductance(Henrys)
:::2. Input Transformer to Push-Pull Circuit:
::: a. Primary and secondary impedance
::: b. Primary and secondary DC resistance
::The entry on this site under Resources for "Clarion/60" gives the DC resistances for these parts.
::For the audio interstage coupling transformer, it will probably be 1:1 so the input characteristics will determine the impedance of both windings. Basically you are matching the plate circuit of a type 24 tube. I don't know what this is offhand, but it is probably in the several Kohm range; maybe even over 10K. Presumably this can be determined from a Type 24 tube datasheet.
::The L2 inductor impedance (DC resistance: 2K) would have been selected to work with the two electrolytic caps in the "pi" filter circuit to have a network impedance peak at around the full-wave rectified DC pulse frequency, which is 120 Hz for North American power. This provides maximum hum suppression. You can calculate this from the impedance equation for a CLC pi network with a center frequency of 120 Hz. My guess is that it will be a couple of Henries.
::Sorry to provide mostly "soft" information but I suspect that hard data on these impedance parameters will be difficult to come by. You may luck out and find a restorer who has actually measured the values of these parts, but that's probably a long shot.
:BTW, I apologize for conflating "inductor value" with "inductor impedance" in the above text.
5/14/2013 8:42:01 PMByron Taylor
