car radio
5/6/2013 2:11:19 PMbud
please help with a ford car radio from a 1941 Mercury. Has model number 6MF593 listed inside the radio. tube line up: 6X5,7B5,7B5,7A7,7A7,7B8.
also can you recommend a replacement for the vibrator. thanks
5/6/2013 5:10:31 PMLewis
:please help with a ford car radio from a 1941 Mercury. Has model number 6MF593 listed inside the radio. tube line up: 6X5,7B5,7B5,7A7,7A7,7B8.
:also can you recommend a replacement for the vibrator. thanks
Bud:
The schematic for that Ford part number can be found here under Zenith. A solid state vibrator might be better than trying to find a replacement mechanical.
Googling "six Volt vibrator" will take you to sites far removed from radios.
5/7/2013 9:50:32 AMbud
::please help with a ford car radio from a 1941 Mercury. Has model number 6MF593 listed inside the radio. tube line up: 6X5,7B5,7B5,7A7,7A7,7B8.
::also can you recommend a replacement for the vibrator. thanks
:Bud:
:The schematic for that Ford part number can be found here under Zenith. A solid state vibrator might be better than trying to find a replacement mechanical.
:Googling "six Volt vibrator" will take you to sites far removed from radios.
:Lewis
thanks Lewis
