You should be able to use a Bogen T725, which is under $5. http://makearadio.com/misc-stuff/t-725.php
Rich
:I dont want to be a burden but I need to ask this question again because Im new to this and need some help. I have a 1946 RCA Radiola model 61-8 that had a bad output transformer that was shorting out my rectifier tube. I tested the transformer and it was shorted internally. I was wanting to know if anyone know a good place to find a new transformer. Ive found the company of Hammond Mfg that has numerous transformers but I dont know which one, if any will work. The output tube is a 50L6GT and from what ive read it takes a transformer with a 2000 ohm impedence primary. I however cant find one with a centertap on the primary like the original one had. Any advise would be GREATLY appreciated.
According to the schematic what Rich advises will work for you.
Mitch
Then there is an insulative overwrap and the overwind of the few turn secondary winding. . Check it out . . . you also just might have that situation, with no transformer winding damages.
:::If you have only one 50L6, I don't understand why you would need a center-tap?
:::You should be able to use a Bogen T725, which is under $5. http://makearadio.com/misc-stuff/t-725.php
:::Rich
::::I dont want to be a burden but I need to ask this question again because Im new to this and need some help. I have a 1946 RCA Radiola model 61-8 that had a bad output transformer that was shorting out my rectifier tube. I tested the transformer and it was shorted internally. I was wanting to know if anyone know a good place to find a new transformer. Ive found the company of Hammond Mfg that has numerous transformers but I dont know which one, if any will work. The output tube is a 50L6GT and from what ive read it takes a transformer with a 2000 ohm impedence primary. I however cant find one with a centertap on the primary like the original one had. Any advise would be GREATLY appreciated.
:::The center tap primary wire is connected to the 35Z5GT rectifier tube and the other two primary wires are connected to the 50L6GT output tube.
:Troy,
:According to the schematic what Rich advises will work for you.
:Mitch
