Grundig-Majestic 5017U
3/26/1999 11:02:51 PMDaniel Gallagher
I recently purchased a Grundig-Majestic 5017U Stereo. All of te tubes light up, but it won't play. What could be the problem? Also, I would like some info on when it was made and how much it's worth.
3/27/1999 10:41:00 AMDave
: I recently purchased a Grundig-Majestic 5017U Stereo. All of te tubes light up, but it won't play. What could be the problem? Also, I would like some info on when it was made and how much it's worth.
Dan,
that only means the 6 or 12 volt filament tap on the power transformer works. i would assume then,the entire transformer is working.you can always put an ohm meter across the secondary. first thing to do is replace the old high voltage filter capacitors right away. Since, if it's stereo, you have 2 complete channels in the amplifer sec..it's unlikley both outputs are open or both preamp triodes and output tubes are bad. If there is not even the slightest hum in either channel or otherwise noise to let you know...then i would say you have a B+ network problem..Get a scheme and an ohm-cap meter and work through the B supply to the output and preamp tubes.
If you do have some kind of indication the amp is working then work back up the af- rf chain looking for bad coupling caps, open resistors, or other R/C problems.. Barring the fact all the tubes show good in a tester.(just because they light doesnt mean a thing)
often you can spot badly heated resistors and poped caps visually.. tapping around with the butt end of a screwdriver with power on will often locate an intermittant connection,,
10 to one if you have no hum or hear anything at all when you switch on the set,,,it's a power supply problem..
dave
11/7/1999 9:32:59 PMMike Herman
: : I recently purchased a Grundig-Majestic 5017U Stereo. All of te tubes light up, but it won't play. What could be the problem? Also, I would like some info on when it was made and how much it's worth.
: Dan,
: that only means the 6 or 12 volt filament tap on the power transformer works. i would assume then,the entire transformer is working.you can always put an ohm meter across the secondary. first thing to do is replace the old high voltage filter capacitors right away. Since, if it's stereo, you have 2 complete channels in the amplifer sec..it's unlikley both outputs are open or both preamp triodes and output tubes are bad. If there is not even the slightest hum in either channel or otherwise noise to let you know...then i would say you have a B+ network problem..Get a scheme and an ohm-cap meter and work through the B supply to the output and preamp tubes.
: If you do have some kind of indication the amp is working then work back up the af- rf chain looking for bad coupling caps, open resistors, or other R/C problems.. Barring the fact all the tubes show good in a tester.(just because they light doesnt mean a thing)
: often you can spot badly heated resistors and poped caps visually.. tapping around with the butt end of a screwdriver with power on will often locate an intermittant connection,,
: 10 to one if you have no hum or hear anything at all when you switch on the set,,,it's a power supply problem..
: dave
I recently found a Grundig Majestic SO 102/60PX in my grandmothers basement, works perfectly, except for the turntable. How do I tell the year and value etc...
3/31/1999 6:40:12 AMPeter
Hi Daniel
I think, Dave is right to look at the anode's power supply.
Now what you also should do with old Grundig's: The caps
for coupling and filtering except the electrolytic ones are
often of the type ERO 100. They are wax-sealed paper capacitors.
The wax shrinked and broke in the last 40 years, humidy got in
and if it's a coupling cap the following tube is not happy about this.
I replace them without testing by better ones wherever possible.
I hope i can find out when the Grundig was made but it should have been
sold here in Germany too (not export version only).
See also 'Grundig 7015 selenium rectifier replacement' in this forum .
Good luck !
11/13/1999 1:10:13 PMBob McGinn
: I was looking for information on the Grundig-Majestic
2120 radio. I would like some info on when it was
Thank You.
Bob M.
11/14/1999 11:40:21 AMDAWN
: I WAS WONDERING WHERE I CAN SERVICE MY GRUNDIG MAJESTIC?
6/28/2000 5:54:08 PMWilliam H. Green Sr.
: : I WAS WONDERING WHERE I CAN SERVICE MY GRUNDIG MAJESTIC? Stero Console model#so 121a the turntable has stopped working and it is not the grease. I live in the Chicago area on the southside.
6/30/2000 9:22:00 PMWilliam H. Green Sr.
10/2/2000 8:42:05 PMazalea gray
My grandmother gave me her antique Grundig Majestic, Hi-Fi stero. It was purchased around the 1950's or early 60's. The serial number is #61611098. can you give me any details on this model and/or the value?
6/30/2000 9:26:52 PMWilliam H. Green Sr.
: : I WAS WONDERING WHERE I CAN SERVICE MY GRUNDIG MAJESTIC STERO CONSOLE MODEL #SO 121A, i NEED A REPAIR SHOP IN THE CHICAGO SOUTH SIDE AREA OR NEAREST LOCATION. A FOLLOW UP NOTE WILL BE GREATLEY APPRECIATED!
7/11/2000 8:04:23 PMlee pettis
All right, here it is. ACT electronics 1-800-824-7094 Long beach Ca.
12/15/1999 7:58:52 PMMe
: I recently found a Grundig-Majestic in the garbage while driving down the street. I Put it in my car and drove off not thinking it was going to work because it was raining. I got home plugged it in and it worked. I was thrilled. I just wanted to know what the starting cost would be for one of these.
5/29/2000 2:37:41 PMAUTRY JAMES
: : I recently found a Grundig-Majestic 7005/usa at a garbage sale. Where can I get info on this system?
10/2/2000 8:39:08 PMazalea gray
: : I recently found a Grundig-Majestic in the garbage while driving down the street. I Put it in my car and drove off not thinking it was going to work because it was raining. I got home plugged it in and it worked. I was thrilled. I just wanted to know what the starting cost would be for one of these.
1/26/2000 12:04:57 PMMichael
Purchased new in 1958 for sale obo
Here in Los Angeles area
1/28/2000 3:22:08 PMMichael Saekel
: Purchased new in 1958 for sale obo
it is a 8068 USA 13 fm 8 broadcast sliding door
: Here in Los Angeles area
3/4/2000 9:12:05 PMKaren Burstyn
I don't know what model I have but it has a turntable with 78,45, 33 speeds, a radio with multi-sonic tone control and made in W. Germany. It all used to work but the tubes, I don't think, work any more. It was left in the house I purchased in Rye, New York. It now resides in Los Angeles, CA. How can I get it tuned up? Anyone know?
Karen
7/11/2000 8:01:14 PMlee pettis
: I don't know what model I have but it has a turntable with 78,45, 33 speeds, a radio with multi-sonic tone control and made in W. Germany. It all used to work but the tubes, I don't think, work any more. It was left in the house I purchased in Rye, New York. It now resides in Los Angeles, CA. How can I get it tuned up? Anyone know
I have a 8095 with the sonic control, Im getting mine fixed at act electronics In long beach. if you want the address, lets talk.
3/4/2000 9:29:31 PMKaren Burstyn
A follow-up - my Grundig is a 7050/USA. Does anyone know where to go to get it in working order?
6/12/2000 1:01:17 AMgary holt
i own a grundig majestic 8050 it was made in west germany it was sold by majestic international corp. 79 washington street brooklyn n.y. also majestic international corp. 743 north la salle street chicago 10 ill. the modle no. is 202763956 it is in perfect condition i have all the papers the tubes in the chassie are inter changable with rca tubes i hAVE A SCHIGMATIC that has the part no. and the instruction book and warranty papers and shipping papers dated when it was shipped a receipt dated 11-9-1957 for $159.95 dollors i have no idea how much it is worth now but to me it is priceless. i love to play it and intertain company with its beutiful german teckwood cabinet. it has sw1-sw2and sw3 ,turntable,am-fm and all of it works and the cabinet is beautiful. wish you could see it.
1/20/2002 11:52:40 AMwilliam baker
does anyone know where i can get it serviced or information regarding replacement parts (tubes)
