Yes, if the radio receives anything at all the IF transformers are probably intact; but they may need to be "peaked" vis a vis the alignment procedure.
Same goes for the radio's front end... if the set doesn't respond to a total alignment, I'd suspect the antenna coils and/or the bandswitch- an open coil or oxidized switch contact could result in severe signal attenuation. However, this shows up usually on just one band- it's unlikely to have multiple band failures.
I have one of these sets and it is a decent performer but it needs a reasonably long antenna to work well- at least 15 feet.
Finally, tubes which "test good" aren't necessarily "good tubes". I've heard it said that while tube testers can always detect a bad tube, they can't be 100% relied on to find good tubes.
::You may just need to do a tuner/IF alignment...
:Yes, if the radio receives anything at all the IF transformers are probably intact; but they may need to be "peaked" vis a vis the alignment procedure.
:Same goes for the radio's front end... if the set doesn't respond to a total alignment, I'd suspect the antenna coils and/or the bandswitch- an open coil or oxidized switch contact could result in severe signal attenuation. However, this shows up usually on just one band- it's unlikely to have multiple band failures.
:I have one of these sets and it is a decent performer but it needs a reasonably long antenna to work well- at least 15 feet.
:Finally, tubes which "test good" aren't necessarily "good tubes". I've heard it said that while tube testers can always detect a bad tube, they can't be 100% relied on to find good tubes.
It is low. Should be in the neighborhood of 130VDC.
Something is severely loading down the B+ bus; or your rectifier tube is punking out. Check for a reversed filter electrolytic cap, and that the red and blue leads to the first IF transformer don't have bare wire exposed and in contact with something else.
http://www.antiqueradios.com/forums/viewforum.php?f=5
Rich
:I have a negative 5volts dc on the first grid of the 12SA7 and scope shows the osc is running. When I touch the scope probe to the plate of the 12SA7 the radio suddenly springs to life a little. Only have about 79 volts dc on plates. Seems low to me.
:::You may just need to do a tuner/IF alignment...
::Yes, if the radio receives anything at all the IF transformers are probably intact; but they may need to be "peaked" vis a vis the alignment procedure.
::Same goes for the radio's front end... if the set doesn't respond to a total alignment, I'd suspect the antenna coils and/or the bandswitch- an open coil or oxidized switch contact could result in severe signal attenuation. However, this shows up usually on just one band- it's unlikely to have multiple band failures.
::I have one of these sets and it is a decent performer but it needs a reasonably long antenna to work well- at least 15 feet.
::Finally, tubes which "test good" aren't necessarily "good tubes". I've heard it said that while tube testers can always detect a bad tube, they can't be 100% relied on to find good tubes.
:John: you will find a lot of S-38 discussion and help on the Antique Radio Forum, in the Communication Receivers section.
:http://www.antiqueradios.com/forums/viewforum.php?f=5
:Rich
::I have a negative 5volts dc on the first grid of the 12SA7 and scope shows the osc is running. When I touch the scope probe to the plate of the 12SA7 the radio suddenly springs to life a little. Only have about 79 volts dc on plates. Seems low to me.
::::You may just need to do a tuner/IF alignment...
:::Yes, if the radio receives anything at all the IF transformers are probably intact; but they may need to be "peaked" vis a vis the alignment procedure.
:::Same goes for the radio's front end... if the set doesn't respond to a total alignment, I'd suspect the antenna coils and/or the bandswitch- an open coil or oxidized switch contact could result in severe signal attenuation. However, this shows up usually on just one band- it's unlikely to have multiple band failures.
:::I have one of these sets and it is a decent performer but it needs a reasonably long antenna to work well- at least 15 feet.
:::Finally, tubes which "test good" aren't necessarily "good tubes". I've heard it said that while tube testers can always detect a bad tube, they can't be 100% relied on to find good tubes.
